MapServer, PostGIS, Subquery with JOIN, WMS GetFeatureInfo / Followup Question
Paul Ramsey pramsey at REFRACTIONS.NET
Fri Feb 24 12:42:23 EST 2006
If you have the option, please don't use oid, use a primary key (like
the 'gid' created by shp2pgsql) as your unique key.  Primary keys
already have indexes, oids do not.  Primary keys show up
automatically in a "select *" query, oids do not.  oids are
deprecated in pgsql and not available by default in pgsql 8.1.
Basically oid is now a deadend, and we need to start erasing all uses
of them.
P
On 24-Feb-06, at 5:09 AM, Jeff Hoffmann wrote:
> Nick Floersch wrote:
>> *From:* Nick Floersch
>> *Sent:* Friday, February 24, 2006 5:03 AM
>> *To:* Nick Floersch
>> *Subject:* RE: MapServer, PostGIS, Subquery with JOIN, WMS
>> After my just previous post to the list, I decided to try my
>> alternative solution...
>>   "" Before anyone suggests the solution of using a view to
>> encapsulate my JOIN so it need not be in the subquery, I'll just
>> say that I am aware I could try that approach (though I have not
>> yet done so), but my curiosity has been piqued by this problem as
>> it is, so I'm hoping to find out more about the JOINs in
>> subqueries issue I have. I would also really love to know how
>> MapServer gets the attribute columns for PostGIS layers. ""
> This is on my "figure out some day myself" list, too.  I'm doing
> the view thing right now, but I'd like to not have to create views
> for everything.
>> ---snip---
>>  The only thing I can think of is... does the PostGIS connector
>> require the table to have OIDs? It looks that way.
> Yes.  It needs some unique field in order to randomly access an
> individual rows, it just so happens that OID is a convenient way to
> get that in most cases.  You can also specify your own unique
> column name with "using unique <column name>" if your view doesn't
> have an OID column but you have some other key you can use.  I just
> pull in the OID from the main geometry-containing table when I
> define the view.
> Jeff Hoffmann
> jeff at propertykey.com
