24-bit image is rendered in greyscale when using CLASS in
LAYER
Frank Warmerdam
warmerdam at POBOX.COM
Mon Feb 27 13:36:50 EST 2006
Julien, Heryk wrote:
> Hi,
> When I add a class item to my raster layer my 24bit RGB tif is rendered
> in greyscale. I need the class item in order to generate a legend item
> in my ogc wms capabilities. In the following bugzilla report a similar
> problem is flagged as fixed however I am using mapserver 4.5 and 4.8.1
> and both versions have the same bug.
Héryk,
You are quite sure this is happening with 4.8.1? It shouldn't be. If you
can submit a bug report with the minimum mapfile and data required to
reproduce the problem I will dig into it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
