ECW Support
Bart van den Eijnden (OSGIS) bartvde at XS4ALL.NL
Wed Jan 4 13:25:23 EST 2006
I have used ECW files on Windows with MS4W in the past. Which version of
MS4W are you using?
Are you able to read the ECW file with gdalinfo (install fwtools from
www.maptools.org/fwtools)? If so, can you post the output of gdalinfo as
well as your LAYER definition in the MAP file?
Are you using Mapserver CGI or PHP/Mapscript to render the ECW?
How large is the ECW file?
Also, try to put debugging on in Mapserver
(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver) and
optionally use CONFIG CPL_DEBUG "ON" at the MAP level in your map file
to get GDAL to output debug info.
Best regards,
Bart
Lawrence Hartpence wrote:
>Hello,
>A day or two ago, I posted a question about ECW support with the MS4W build
>of MapServer.  I have MapServer on a Windows 2000 machine running with IIS.
>I read a thread stating that on a LINUX machine you need to modify GDAL to
>make it support ECW files.  Is this the case with Windows machines?  The
>only response I received the other day was that this build should support
>ECW files.  Is there anyone out there using ECW files with windows?
>I try to add the ECW file in my mapfile like I would a TIF and the browser
>just hangs up when I try to do this and times out.
>Thanks!!
>Lawrence Hartpence
>GIS Coordinator
>101 1st St N
>Newton IA 50208
>641-792-3084
>hartpence_gis at co.jasper.ia.us
OSGIS, Open Source GIS
http://www.osgis.nl
