Mandatory metadata warnings
Graham Davis
gdavis at REFRACTIONS.NET
Mon Jan 9 20:01:00 EST 2006
Hi James,
Try the following:
MAP
NAME "SYSTEM"
IMAGETYPE jpeg
EXTENT 140 -41 150 -33
SIZE 1024 1024
DEBUG ON
IMAGECOLOR 0 0 0 # The background Color.
WEB
LOG 'my_log.txt' # The Debug Log.
TEMPLATE 'start_template.html'
IMAGEPATH '/var/www/html/tmp/'
IMAGEURL '/tmp/'
WMS_TITLE "My Title"
END
PROJECTION
"init=epsg:4283"
END
LAYER
NAME "my_map"
DATA "/my_map_GDA94.tif"
TYPE RASTER
STATUS DEFAULT
METADATA
wms_title "my_map"
wms_srs "EPSG:4283"
END
END
Graham Davis
Refractions Research Inc.
gdavis at refractions.net
James Net wrote:
> Hi all,
> I just did a REQUEST=GetCapabilities on my wms map and I got a few
> mandatory warnings. How and where do I add this metadata?
> The first warning is:
> <WMT_MS_Capabilities version="1.1.1">
> MapServer version 4.6.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=TIFF
> INPUT=EPPL7 INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> <Service>
> <Name>OGC:WMS</Name>
> WARNING: Mandatory metadata '..._title' was missing in this context.
> <Title>SYSTEM</Title>
> <OnlineResource
> xlink:href="http://test/cgi-bin/mapserv?map=vicmap.map&"/>
> </Service>
> Where should I add "wms_title" in my map file?
> Next warning:
> <Layer>
> <Name>SYSTEM</Name>
> <SRS>EPSG:4283</SRS>
> <LatLonBoundingBox minx="140" miny="-41" maxx="150" maxy="-33"/>
> <BoundingBox SRS="EPSG:4283" minx="140" miny="-41" maxx="150"
> maxy="-33"/>
> <Layer queryable="0" opaque="0" cascaded="0">
> <Name>my_map</Name>
> <Title>my_map</Title>
> </Layer>
> Why does SYSTEM report as a layer? And where do I add "wms_title" to
> stop this warning???
> And here is my simple map file:
> MAP
> NAME SYSTEM
> IMAGETYPE jpeg
> SIZE 1024 1024
> DEBUG ON
> WEB
> IMAGEURL '/tmp/'
> END
> PROJECTION
> "init=epsg:4283"
> END
> LAYER
> NAME "my_map"
> TYPE RASTER
> STATUS DEFAULT
> METADATA
> wms_title "my_map"
> wms_srs "EPSG:4283"
> END
> END
> Thanks heap in advance.
> _________________________________________________________________
> realestate.com.au: the biggest address in property
> http://ninemsn.realestate.com.au
