Mandatory metadata warnings
James Net james_marsnett at HOTMAIL.COM
Mon Jan 9 20:01:53 EST 2006
That's great! It solved 'em all! Thanks again.
>From: Graham Davis <gdavis at REFRACTIONS.NET>
>Reply-To: Graham Davis <gdavis at REFRACTIONS.NET>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Mandatory metadata warnings
>Date: Mon, 9 Jan 2006 17:01:00 -0800
>Hi James,
>Try the following:
>MAP
>    NAME              "SYSTEM"
>    IMAGETYPE          jpeg
>    EXTENT             140 -41 150 -33
>    SIZE               1024 1024
>    DEBUG         ON
>    IMAGECOLOR    0 0 0 # The background Color.
>    WEB
>        LOG       'my_log.txt' # The Debug Log.
>        TEMPLATE  'start_template.html'
>        IMAGEPATH '/var/www/html/tmp/'
>        IMAGEURL  '/tmp/'
>       WMS_TITLE "My Title"
>    END
>    PROJECTION
>        "init=epsg:4283"
>    END
>    LAYER
>        NAME     "my_map"
>        DATA     "/my_map_GDA94.tif"
>        TYPE     RASTER
>        STATUS    DEFAULT
>        METADATA
>            wms_title    "my_map"
>            wms_srs        "EPSG:4283"
>        END
>    END
>Graham Davis
>Refractions Research Inc.
>gdavis at refractions.net
>James Net wrote:
>>Hi all,
>>I just did a REQUEST=GetCapabilities on my wms map and I got a few
>>mandatory warnings. How and where do I add this metadata?
>>The first warning is:
>><WMT_MS_Capabilities version="1.1.1">
>>MapServer version 4.6.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>>SUPPORTS=WMS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=TIFF
>>INPUT=EPPL7 INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
>>     <Service>
>><Name>OGC:WMS</Name>
>>WARNING: Mandatory metadata '..._title' was missing in this context.
>><Title>SYSTEM</Title>
>><OnlineResource xlink:href="http://test/cgi-bin/mapserv?map=vicmap.map&"/>
>></Service>
>>Where should I add "wms_title" in my map file?
>>Next warning:
>><Layer>
>><Name>SYSTEM</Name>
>><SRS>EPSG:4283</SRS>
>><LatLonBoundingBox minx="140" miny="-41" maxx="150" maxy="-33"/>
>><BoundingBox SRS="EPSG:4283" minx="140" miny="-41" maxx="150" maxy="-33"/>
>><Layer queryable="0" opaque="0" cascaded="0">
>><Name>my_map</Name>
>><Title>my_map</Title>
>></Layer>
>>Why does SYSTEM report as a layer? And where do I add "wms_title" to stop
>>this warning???
>>And here is my simple map file:
>>MAP
>>     NAME               SYSTEM
>>     IMAGETYPE          jpeg
>>     SIZE               1024 1024
>>     DEBUG         ON
>>     WEB
>>         IMAGEURL  '/tmp/'
>>     END
>>     PROJECTION
>>         "init=epsg:4283"
>>     END
>>     LAYER
>>         NAME     "my_map"
>>         TYPE     RASTER
>>         STATUS    DEFAULT
>>         METADATA
>>             wms_title    "my_map"
>>             wms_srs        "EPSG:4283"
>>         END
>>     END
>>Thanks heap in advance.
>>_________________________________________________________________
>>realestate.com.au: the biggest address in property
>>http://ninemsn.realestate.com.au
Start something musical - 15 free ninemsn Music downloads!
http://ninemsn.com.au/share/redir/adTrack.asp?mode=click&clientID=667&referral=HotmailTaglineNov&URL=http://www.ninemsn.com.au/startsomething
