FW: Mapserver for Oracle spatial 10G
Ruiter E. de (Erik)
E.Ruiter at ARCADIS.NL
Tue Jan 10 07:12:26 EST 2006
Hi Fernando,
I just see a blank image, no more error messages, the error produced by
the debug mode in the error.log file is:
[Tue Jan 10 12:48:48 2006] [error] [client 127.0.0.1] msDrawMap():
Drawing Label Cache, 0.000s\r
[Tue Jan 10 12:48:48 2006] [error] [client 127.0.0.1] msDrawMap() total
time: 0.000s\r
I've made an export from a oracle 9.2 database and imported it into our
oracle 10g database.
Also I've already tried several variations of the mapfile, with and
without projection definitions.
Greetings,
Erik.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Fernando Simon
Sent: dinsdag 10 januari 2006 13:02
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] FW: Mapserver for Oracle spatial 10G
Hi folks,
Sorry for the delay to reply your message, about the Oracle Spatial
support in Mapserver you can use since 8i, 9i and 10G versions without
problems.
About the debug, you need to add "DEBUG ON" in your layer and in
your Map. The Mapserver how to for Oracle Spatial connection you can see
in this link:
"http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto".
About your problem, what's happen, any error message or just a blank
image? How you imported your data in the database? Using shp2sdo? Are
already tried to draw without projection definitions?
Last year I did a page that contains some examples of Oracle Spatial
connection using Mapserver in CGI mode. This page contains the MAP and
QUERY modes. Link:
"http://siaiacad09.univali.br/removidos/G10NOVO/htdocs/maporaclespatial/
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
UNIVALI - CTTMar - Brazil
Citando "Ruiter E. de (Erik)" <E.Ruiter at ARCADIS.NL>:
> Hi Bart and other users,
> I switched on debugging by placing : DEBUG ON at map level and at
> layer level in my mapfile.
> These are the error.log and access.log files. I can't make any sense
> of it.
> Greetings,
> Erik.
> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Sent: maandag 9 januari 2006 15:30
> To: Ruiter E. de (Erik)
> Subject: RE: FW: Mapserver for Oracle spatial 10G
> Hoi Erik,
> Probeer eens debuggen aan te zetten.
> Zet DEBUG ON op je LAYER object en evt op je MAP object.
> Als je IIS gebruikt, zet environment variabele MS_ERRORFILE op stderr
> en herstart server.
> Als je Apache gebruikt, zet MS_ERRORFILE dan via SetEnv in de
> httpd.conf en herstart Apache.
> In de error log van je webserver komt dan debug info.
> Groeten,
> Bart
> > Hi Bart,
> > many thanks for the files and the quick response.
> > However my problem still exists, I've overwritten the mapserv.exe
> and
> > the others with your files, but I still don't see anything.
> > I can't seem to find what I'm doing wrong.
> > My mapfile looks like:
> > # MAPFILE Spinoffice
> > #============ MAIN MAP
> > MAP
> > NAME "Spinoffice"
> > SIZE 400 200
> > EXTENT 123161.184000 425974.862000 130445.273000 430555.785000
> > IMAGECOLOR 255 255 0 IMAGETYPE png SHAPEPATH "shapes"
> > SYMBOLSET "../symbols/symbols35.sym"
> > WEB
> > TEMPLATE "../html/mapserver.html"
> > IMAGEPATH '/ms4w/tmp/ms_tmp/'
> > IMAGEURL '/ms_tmp/'
> > END
> > PROJECTION
> > "init=epsg:28992"
> > END
> > #============ LAYERS
> > LAYER
> > NAME Gebouwen
> > TYPE POLYGON
> > STATUS ON
> > CONNECTIONTYPE oraclespatial
> > CONNECTION "bag/bag at maatwerk"
> > DATA "N0320 FROM GEBOUW USING SRID 90112"
> > PROCESSING "CLOSE_CONNECTION=DEFER"
> > PROJECTION
> > "init=epsg:28992"
> > END
> > CLASS
> > NAME "gebouw"
> > SIZE 1
> > STYLE
> > COLOR 0 255 255
> > OUTLINECOLOR 32 32 32
> > END
> > END
> > END
> > END
> > The url :
http://localhost:80/cgi-bin/mapserv.exe?map=C:/Mapfiles/spinoffice.map
> > &l
> > ayer=gebouwen&mode=map
> > Any help would be greatly appreciated.
> > greetings,
> > Erik.
> > ________________________________
> > From: Bart van den Eijnden (OSGIS) [mailto:bartvde at xs4all.nl]
> > Sent: zaterdag 7 januari 2006 12:22
> > Cc: hobu at iastate.edu; pnaciona at gis.umn.edu
> > Subject: Re: FW: Mapserver for Oracle spatial 10G
> > Hi Erik,
> > I just built a mapserv.exe for you against the Oracle 10.2.0.1
> libs.
> > You can download from (as you probably know I can't provide you
> with
> > the oci.dll because of Oracle's license, but I am sure you have
> that
> > already on your system):
> > http://www.osgis.nl/arcadis.zip
> > The build info is:
> > MapServer version 4.8.0-rc1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP OUTPUT =SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> > SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUP PORTS=WCS_SERVER
> > INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=
> > MSDEBUG
> > Best regards,
> > Bart
> > Ruiter E. de (Erik) wrote:
> > Dear Howard and Bart,
> > Please see the mail below from me to Perry?
> > I'm looking for mapserver binaries which support oracle 10g.
> > Thank in advance.
> > Greetings,
> > Erik.
> > -----Oorspronkelijk bericht-----
> > Van: Pericles S. Nacionales [mailto:pnaciona at gis.umn.edu]
> > Verzonden: vrijdag 6 januari 2006 20:06
> > Aan: Ruiter E. de (Erik)
> > Onderwerp: Re: Mapserver for Oracle spatial 10G
> > Hi Erik,
> > You might want to send Howard Butler <hobu at iastate.edu>
> > <mailto:hobu at iastate.edu> or Bart van den
> > Eijnden <bartvde at xs4all.nl> <mailto:bartvde at xs4all.nl> as they
> are
> > the two I know who use Oracle
> > and Windows. Howard's Windows binaries are available at
> > http://hobu.stat.iastate.edu/mapserver/
> > Is there a known incompatibility between Oracle 9i client and
> an
> > Oracle
> > 10g server? Give it a test and see if it does what you want.
> > If it
> > doesn't send Howard or Bart an e-mail.
> > Good luck with the demo!
> > -Perry
> > On Friday 06 January 2006 06:34, you wrote:
> > Hi Perry,
> > A very happy new year to you!
> > Please excuse me that I post this directly to you but
> the UMN site
> > seems to be down and I can't find a way to access the
> user-list as
> > someone with posting-rights. Also, we have a demo coming
> up so we're
> > in a bit of a hurry.
> > As you can see (and maybe remember) in the mail below,
> we use ms4w
> > for
> > our web-application. We have oracle spatial data that we
> would like
> > to
> > visualise, however we don't have experience compiling
> mapserver (and
> > we don't want to, to be honest). I've managed to find a
> version of
> > mapserv.exe which supports Oracle spatial natively. Now
> we want to
> > upgrade to Oracle 10g but my version of mapserv.exe
> seems to only
> > support oracle 9i.
> > Do you have or happen to know someone who has a
> mapserver binary for
> > windows with Oracle 10G support?
> > Greetings and thanks in advance,
> > Erik de Ruiter.
> > Arcadis Spatial Information.
> > The Netherlands.
> > From: Pericles S. Nacionales
> > Sent: dinsdag 27 september 2005 18:24
> > Subject: Re: mapserver tutorial
> > Erik,
> > Thanks for your interest in MapServer, the tutorial is
> still in
> > draft
> > form but should be working. You can download it at
> > http://hypnos.cbs.umn.edu/tutorial/tutorial.zip. You
> will also need
> > to download and install MS4W which is downloadable at
> > http://www.maptools.org/dl/.
> > Good luck!
> > -Perry N.
> > On Tuesday 27 September 2005 05:06, you wrote:
> > Dear Perry,
> > currently we are busy investigating different
> webmapping
> > technologies and choose one to use within our
> web-application. To
> > get acquainted with mapserver for this purpose I
> would like to
> > obtain a copy of the mapserver fro windows
> tutorial.
> > Of course I'm willing to to give you or the
> forum feedback on my
> > findings such to contribute to the further
> development.
> > thanks in advance.
> > greetings,
> > Erik de Ruiter.
> > Arcadis Spatial Information (KLM Aerocarto).
> > The Netherlands.
> > Conservation Biology Program
> > University of Minnesota
> > 1530 Cleveland Ave. N., 115GrnH
> > St. Paul, MN 55108
> > [DISCLAIMER]
> > Dit e-mail bericht is vertrouwelijk. Het is uitsluitend
> bestemd voor
> > de geadresseerde. Indien u niet de geadresseerde bent,
> verzoeken we
> > u
> > dringend ons direct te informeren en om dit bericht en
> eventuele
> > bijlage(n) te verwijderen, zonder het te kopieren, door
> te zenden of
> > op enige andere wijze te openbaren of te gebruiken.
> > ARCADIS is niet
> > aansprakelijk voor welke schade dan ook als gevolg van
> communicatie
> > per e-mail en verzending van documenten en gegevens.
> > This e-mail is confidential and may also be privileged.
> > It is intended
> > for use by the addressee only. If you are not the
> intended
> > addressee,
> > we request that you notify us immediately and delete
> this e-mail,
> > and
> > any attachment(s), without copying, forwarding,
> disclosing or using
> > it
> > in any other way. ARCADIS will not be liable for damage
> relating to
> > the communication by e-mail of data or documents.
> > St. Paul, MN 55108
> > OSGIS, Open Source GIS
> > http://www.osgis.nl
Univali - Webmail - http://webmail.univali.br
