SLD http header problem
Bart van den Eijnden (OSGIS) bartvde at XS4ALL.NL
Tue Jan 10 11:46:35 EST 2006
Hi Debbie, Phil,
I don't know what this says about your organization's security :-) , but
I can access the SLD (and could already before) at:
http://map.ns.ec.gc.ca/kyw/sld/kyw_sld.xml
without any problems. Could not see anything obviously wrong though.
Best regards,
Bart
Pagurek,Debbie [NCR] wrote:
> Phil, you might want to post your SLD here so people can check it out.
> I briefly looked at your SLD (because I'm internal to your
> organization) - I would first try to isolate the SLD to deal with JUST
> the layer that you are trying to style. Also - compare your SLD to
> others that are out there to double check syntax etc.
> D. Pagurek
>     -----Original Message-----
>     *From:* UMN MapServer Users List
>     [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Chau,Philip
>     [PYR]
>     *Sent:* Monday, January 09, 2006 12:50 PM
>     *To:* MAPSERVER-USERS at LISTS.UMN.EDU
>     *Subject:* [UMN_MAPSERVER-USERS] SLD http header problem
>     I'm trying to display the layer and using SLD to change the symbol
>     (ActiveFedProv) and it seems to be giving me a problem
>     _http://excise.pyr.ec.gc.ca/cgi-bin/pyrwqmp.asp?version=1.1.1&service=WMS&request=GetMap&layers=ActiveFedProv&SLD=http://map.ns.ec.gc.ca/kyw/sld/kyw_sld.xml_
>     <http://excise.pyr.ec.gc.ca/cgi-bin/pyrwqmp.asp?version=1.1.1&service=WMS&request=GetMap&layers=ActiveFedProv&SLD=http://map.ns.ec.gc.ca/kyw/sld/kyw_sld.xml>
>     WMS GetCapabilities seems to say that it supports SLD however I
>     get a CGI error
>     "CGI Error
>     The specified CGI application misbehaved by not returning a
>     complete set of HTTP headers. The headers it did return are:
>     Cheers,
>     Phil
>     Philip Chau, PMP
>     Water Quality Monitoring Division
>     Environmental Stewardship Branch
>     Environment Canada
>     201-401 Burrard Street
>     Vancouver, BC V6C 3S5
>     Tel: 604.664.4066
>     Fax: 604.664.9126
OSGIS, Open Source GIS
http://www.osgis.nl
