problem in compiling 4.8-rc3
Sean Gillies
sgillies at FRII.COM
Sun Jan 29 08:25:39 EST 2006
On Jan 29, 2006, at 12:23 AM, John Cartwright wrote:
> Hello All,
> I'm having a problem compiling 4.8 that seems to be related to the
> gdFontCacheSetup check:
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... no
> checking for libiconv_open in -liconv... no
> checking for libiconv_open in -liconv... yes
> using libiconv from system libs.
> libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.16 or higher...
> checking for gdFontCacheSetup in -lgd... no
> configure: checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.la/libgd.so in
> /usr/local/graphicslibs/lib. Make sure GD 2.0.16 or higher is
> compiled
> before calling configure. You may also get this error if you didn't
> specify the appropriate location for one of GD's dependencies
> (freetype,
> libpng, libjpeg or libiconv).
> I'm using the same gd-2.0.33 and configuration line that compiled
> successfully for 4.6.0.
> I've been able to replicate the problem on both a RedHat ES3 amd
> Mac OS
> 10.4 system.
> Thanks for any help!
> -- john
Hi John,
Thanks for trying out the release candidate! It configures and builds
for me with no problems. My Fedora system has GD 1.8.4 in /usr/lib,
and I have GD 2.0.33 installed at /usr/local/lib. To keep the
configuration straight I make sure to specify --with-gd=/usr/local.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
