problem in compiling 4.8-rc3
John Cartwright John.C.Cartwright at NOAA.GOV
Sun Jan 29 12:14:55 EST 2006
Thanks for your prompt reply, Sean!
Strangely, the problem seems to be explicitly giving the location of
some of the graphic libs (e.g. zlib, png, etc.) rather than letting them
be found on their own). Fomerly the configuration looked like:
./configure --prefix=/extra/contrib/mapserver-4.8 \
  --with-freetype=/usr/bin/freetype-config    \
  --with-zlib=/usr/lib                        \
  --with-png=/usr/lib                         \
  --with-jpeg=/usr/lib                        \
  --with-xpm=/usr/X11R6/lib                   \
  --with-gd=/extra/contrib/gd-2.0.33          \
  --with-proj=/extra/contrib/proj-4.4.9       \
  --with-geos=/extra/contrib/geos-2.1.1/bin/geos-config \
  --with-ogr=/extra/data/gdal-1.3.1/apps/gdal-config \
  --with-gdal=/extra/data/gdal-1.3.1/apps/gdal-config \
  --with-tiff=/usr/lib                        \
  --with-wfs                                  \
  --with-wcs                                  \
  --with-wmsclient                            \
  --with-wfsclient                            \
  --with-curl-config=/usr/bin
If I pull the configure lines for tiff, png, jpeg, zlib; configure finds
them in the system libs and seems to be OK.  Does this make sense to you?
Thanks again!
-- john
----- Original Message -----
Date: Sunday, January 29, 2006 6:25 am
Subject: Re: problem in compiling 4.8-rc3
> On Jan 29, 2006, at 12:23 AM, John Cartwright wrote:
> > Hello All,
> > I'm having a problem compiling 4.8 that seems to be related to the
> > gdFontCacheSetup check:
> > configure: checking where libiconv is installed...
> > checking for iconv_open in -lc... no
> > checking for libiconv_open in -liconv... no
> > checking for libiconv_open in -liconv... yes
> >         using libiconv from system libs.
> >         libiconv found. Enabling internationalization (-DUSE_ICONV)
> > configure: checking for GD 2.0.16 or higher...
> > checking for gdFontCacheSetup in -lgd... no
> > configure: checking whether GD needs libiconv...
> > configure: error: Could not find gd.h or libgd.la/libgd.so in
> > /usr/local/graphicslibs/lib.  Make sure GD 2.0.16 or higher is
> > compiled
> > before calling configure. You may also get this error if you didn't
> > specify the appropriate location for one of GD's dependencies
> > (freetype,
> > libpng, libjpeg or libiconv).
> > I'm using the same gd-2.0.33 and configuration line that compiled
> > successfully for 4.6.0.
> > I've been able to replicate the problem on both a RedHat ES3 amd
> > Mac OS
> > 10.4 system.
> > Thanks for any help!
> > -- john
> Hi John,
> Thanks for trying out the release candidate! It configures and
> builds
> for me with no problems. My Fedora system has GD 1.8.4 in /usr/lib,
> and I have GD 2.0.33 installed at /usr/local/lib. To keep the
> configuration straight I make sure to specify --with-gd=/usr/local.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com/news
