Sigh... How do I make an OGR connection with mysql ?
Phillip Neal pneal at MBL.EDU
Sat Jul 1 10:20:03 EDT 2006
Hi Mike,
Thank you for your response.
On Jul 1, 2006, at 10:10 AM, Mike D'Ambrogia wrote:
> offlist reply...  have you tried naming the fields in the select vs
> using * in the ovf file?
Yep. I just tried that and I get the same 'missing' message.
Phil
> i.e. select id, latitude, longitude  FROM sites
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-
> USERS at LISTS.UMN.EDU] On Behalf Of Phillip Neal
> Sent: Saturday, July 01, 2006 7:00 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Sigh... How do I make an OGR
> Dear Mapserver people,
> I am trying to serve some data by WFS. I want to get the data
> directly out of a mysql database
> table.
> I have read the wiki , etc and searched around on the web for some
> answers but nothing
> seems to help. Here is my  layer:
> LAYER
>     NAME "sites"
>         METADATA
>         "wfs_title"    "sites" ## REQUIRED
>         "gml_include_items" "all"  ## Optional (serves all
> attributes for layer)
>         END
>     STATUS ON
>     TYPE POINT
>         DUMP TRUE
>     CONNECTIONTYPE OGR
>     CONNECTION "/var/www/docs/sites.ovf"
>     DATA "sites"
>     CLASS
>        STYLE
>             COLOR 0 0 0
>        END #style
>    END #class
> END   #layer
> Here is my ovf file:
> <OGRVRTDataSource>
>     <OGRVRTLayer name="sites">
> <SrcDataSource>MYSQL:mydb,user=myuser,password=mypasswd,port=3306,tabl
> es
> =sites</SrcDataSource>
>         <SrcSQL>SELECT *  FROM sites</SrcSQL>
>         <GeometryType>wkbPoint</GeometryType>
>         <GeometryField encoding="PointFromColumns" x="latitude"
> y="longitude"/>
>     </OGRVRTLayer>
> </OGRVRTDataSource>
> Here is my output (view sourced)
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <wfs:FeatureCollection
>    xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>    xmlns:wfs="http://www.opengis.net/wfs"
>    xmlns:gml="http://www.opengis.net/gml"
>    xmlns:ogc="http://www.opengis.net/ogc"
>    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>    xsi:schemaLocation="http://www.opengis.net/wfs http://
> schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
> http://somewhere/cgi-bin/mapserv-4.8.3?
> SERVICE=WFS&amp;VERSION=1.0.0&amp;REQUEST=DescribeFeatureType&amp;TYPE
> NAME=sites&amp;OUTPUTFORMAT=XMLSCHEMA">
>    <gml:boundedBy>
>       <gml:null>missing</gml:null>
>    </gml:boundedBy>
> </wfs:FeatureCollection>
> OGRINFO says everything is ok:
> >$ ./ogrinfo sites.ovf
> ERROR 4: Update access not supported for VRT datasources.
> Had to open data source read-only.
> INFO: Open of `sites.ovf'
> using driver `VRT' successful.
> 1: sites (Point)
> and
> >$ ./ogrinfo sites.ovf -al
> Layer name: sites
> Geometry: Point
> Feature Count: 8
> Extent: (45.916000, -129.985000) - (60.900000, -25.000000)
> Layer SRS WKT:
> (unknown)
> sample_id: String (255.0)
> latitude: Real (22.0)
> longitude: Real (22.0)
> depth: Real (22.0)
> temp: Real (22.0)
> cell_conc: Real (22.0)
> description: String (255.0)
> notes: String (0.0)
> date_collected: DateTime (0.0)
> OGRFeature(sites):2
>   id (Integer) = 2
>   sample_id (String) = 53
>   latitude (Real) =                     58
>   longitude (Real) =                    -29
>   depth (Real) =                   1400
>   temp (Real) =                      4
>   cell_conc (Real) =                  64000
>   description (String) = (Labrador Sea Water), Eastern Atlantic Basin
>   notes (String) = The water masses were identified based on the
> Sal, Temp characteristics.
>   date_collected (DateTime) = 2002/09/16  0:00:00
>   POINT (58.299999999999997 -29.132999999999999 0)
> and a curl result returns:
>  curl http://somewhere/cgi-bin/mapserv-4.8.3?map=/var/www/docs/
> sites_wfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=si
> tes
> [1] 18085
> [2] 18086
> [3] 18087
> [4] 18088
> $ <HTML>
> <HEAD><TITLE>MapServer Message</TITLE></HEAD>
> <!-- MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=THREADS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE   -->
> <BODY BGCOLOR="#FFFFFF">
> mapserv(): Web application error. No template provided. <br>
> </BODY></HTML>
> [1]   Done                    curl http://somewhere/cgi-bin/
> mapserv-4.8.3?map=/var/www/docs/sites_wfs.map
> [2]   Done                    SERVICE=WFS
> [3]-  Done                    VERSION=1.0.0
> [4]+  Done                    REQUEST=getfeature
> What am I doing wrong ?
> Best regards,
> Phil Neal
> Phillip Neal
> pneal at mbl.edu
> "An ocean without its unnamed monsters would be like a completely
> dreamless sleep."
> John Steinbeck - 'The Log from the Sea of Cortez'
Phillip Neal
pneal at mbl.edu
dreamless sleep."
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060701/7486953b/attachment.html
