Oracle10g and queryByAttributes
Fernando Simon
fsimon at UNIVALI.BR
Mon Jul 3 09:48:38 EDT 2006
Hi Antonio,
How did you defined your DATA parameter for you layer? The extents
for your query are right?
Here I use this code as example:
// Performing the query and returning only a single record
@$qlayer->queryByAttributes($nm_field_query, $regex, MS_SINGLE);
$numresults = $qlayer->getNumResults();
if ($numresults > 0)
for($f = 0; $f < $numresults ; $f++)
// Opening the layer to return data
$qlayer->open();
// Getting the object that store the results
$indexResult = $qlayer->getResult($i);
$qresult =
$qlayer->getShape(-1,$indexResult->shapeindex);
// Getting the data from object
// The "values" contains the data
// for all columns that are in layer data definition
// You can get all columns that are in data
definition
$dataResult = array($qresult->values[STATE]);
// Cleaning and closing objects
$qresult->free();
$qlayer->close();
return $dataResult[0];
And my DATA definition:
data "geo_column from (SELECT geo_id, state, totpop, geo_column
FROM tb_states) USING UNIQUE geo_id FILTER"
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Antonio Iandolo wrote:
> I'm querying Oracle10g with phpmapscript (MapServer 4.8.3) but I can't
> browse the result set...
> Here it is my code:
> $myresult=$mylayer->queryByAttributes($queryItem,$queryString,MS_SINGLE)
> var_dump($myresult);
> if ($mylayer->getNumResults() > 0){
> $mylayer->open();
> $result=$mylayer->getResult($i);
> $shp=$mylayer->getShape(-1,$myresult->shapeindex);
> var_dump($shp);
> >From the output I can see that:
> 1) var_dump($myresult) is "object(stdClass)(3) { ["shapeindex"]=>
> int(-2028233538) ["tileindex"]=> int(-1) ["classindex"]=> int(0) }"
> 2) var_dump($shp) is "False"
> It displays numresults=1 but it $myresult->shapeindex is negative...
> What's wrong? Maybe this is not the right way to query Oracle
> (queryByAttributes) to get data?
> Thanks in advance,
> Antonio
