Limit Number of Results with QSTRING?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Jul 4 01:32:24 EDT 2006
Strange as it sounds there is no way to limit the number of features returned (unless
you are using straight mode=query). I guess I always figured why would you want
to do that. It's not like a Google search where results are sorted by relevance, so
stopping at some limit didn't make much sense. Sorry (please file a bug and I'll try
to address the problem). I do believe the WFS server does have that ability if you
really need it right away.
There is no reason [nr] should max out at 148. Perhaps you've uncovered a bug?
Or something else is going on.
Steve
>>> "Sievers, Jason" <jsievers at CO.LINN.OR.US> 07/03/06 6:01 PM >>>
I would like to know if it is possible to limit the number of results using
QSTRING in CGI MapServer. I can use MAXFEATURES when doing a spatial
search, but this does not seem to work for attribute queries (at least for
me). This is a problem when there is a large results set and MapServer has
to draw every feature matching the expression. I've noticed that the
maximum number of records ([nr]) is 148 but this still will draw on the map
every feature matching the QSTRING expression. Thanks for the help.
Jason Sievers
Linn County, Oregon
