PERL interface trouble
Bruce Cheney BLC at JUB.COM
Wed Jul 5 14:22:10 EDT 2006
Joe, I am not answering your question - I have the same problem and am
hoping to get some help. I am having the same problem using PHP and
mapscript.  I am able to open a file for reading and writing from PHP in
the temporary folder, but always get the error "unable to open file for
writing" when using the same directory with mapscript.  If I eliminate
the path in the 'image->save' command then the image is written to the
'cgi-bin' directory successfully. This location is not where we would
like to read and write files from. I assume there is just some setting
that I have missed that would allow writing to the temporary folder.  We
have the alias to that folder defined in the apache conf file.
I have the same question that Joe has.  Is there something else I need
to do?
Bruce Cheney
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Joe Bussell
Sent: Wednesday, July 05, 2006 11:19 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] PERL interface trouble
Thank you!  I have mode some progress.  The fact that my fonts/
directory was not readable escaped my notice.  The msGetErrorString
function provided that data right away.
I have still have some undesired behavior however.  I added $img->save(
$outfile ); carp mapscript::msGetErrorString("\n");
And it indicates that my image file is not openable for write.  I have
verified that the entire directory chain indicated in the message is
world writable.  Is there something else that I need to do?
[Mon Jul  3 15:52:17 2006] -e: Failure: msSaveImageGD(): Unable to
access file.
Unable to open file
/usr/routing/routes/Route1151967137028128.223.40.5.png for writing at
/usr/routing/perl/dwarp/mapdrawing.pm line 515
I changed my write directory to be a child of /tmp, and everything
worked out just fine.  I verified that the directory permissions matched
and could not find any reference in my httpd.conf that would preclude
writing to a directory off of /usr.  Any ideas as to why this is?
Joe Bussell
On Time Systems
Steve Lime wrote:
> You can get at the MapServer error stack with a call like:
>   my $map = new mapscript::mapObj( $mapfile ) or
> That may help, or be something to try. I use perl MapScript with 4.8
and the CVS version all the time with good results.
> Steve
>>>>Joseph Bussell <joe at OTSYS.COM> 6/30/2006 2:09:06 PM >>>
> Does anyone use the latest code with PERL Mapscript?  If shp2img works
> with my mapfile, is there anything else I can do to understand why my
> new call for the mapObj fails?
> Joe Bussell
> On Time Systems
> Joseph Bussell wrote:
>>I have verified that shp2img constructs an image that derives form my
>>mapfile.  This part looks good.  My mapscript code was written for
>>4.4.2, but the one function that is failing does not appear to have
>>significantly changed.  I am not getting past construction of the
>>basic mapObj from the mapfile.  Specifically, the call to :
>>my $map = new mapscript::mapObj( $mapfile ) or  carp "Could not create
>>mapscript object from mapfile: $mapfile";
>>produces the error message.  I also went into mapscript.pm and added
>>debug code there to be sure I was using the correct module.  The low
>>level call is producing an unusable result.
>>Joe Bussell
>>On Time Systems
>>Stephen Woodbridge wrote:
>>>Hi Joe,
>>>A couple of things.
>>>1) what version does you existing code work on?
>>>2) There are probably two areas that you will need to change
>>>   a) the mapfile
>>>   b) the perl
>>>I would start with using shp2img to make sure you mapfile can load.
>>>It will at least print errors that you can read.
>>>shp2img -m /path/to/file.map -o junk.png ...
>>>Once you can get an image then you will probably have more luck
>>>tracking down the various mapscript changes. These will depend on
>>>what version of mapscript your code was written for.
>>>-Steve W.
>>>>Greetings Listers,
>>>>  It has been a while since I deployed a new Mapserver application.
>>>>I have been leaning on old source on an old box to get the work
>>>>done.  I have been given a new server to set up for our Air Force
>>>>project and have had some issues with getting my code to work.
>>>>First of all I am using Mapscript ala PERL.  I recognize that the
>>>>PERL interface has not been updated due to a lack of user interest,
>>>>but I am still partial to using it if it can still be done (mostly
>>>>since I will not have to rewrite my routing path functionality).
>>>>  My problem is getting the actual mapObj to construct from my
>>>>mapfile.  I have not been able to get any debug information our by
>>>>checking /tmp/mserrors, which used to work nicely in such cases.
>>>>All I get is an undefined reference.  My code for construction is
>>>>simple:
>>>>create mapscript object from mapfile: $mapfile";
>>>>in my httpd.conf I define
>>>>MS_ERRORFILE              /tmp/mserrors.txt
>>>>My mapfile exists and is very simple.
>>>>I am running:
>>>>CentOS release 4.3
>>>>AMD64, dual core machine
>>>>Apache/2.0.52
>>>>mapserver-4.8.3.tar.gz
>>>>perl, v5.8.5 built for x86_64-linux-thread-multi
>>>>Thank you for your time.
>>>>Joe Bussell
>>>>On Time Systems
