PERL interface trouble
Simpson
drewsimpson at BELLSOUTH.NET
Wed Jul 5 14:17:52 EDT 2006
Is /usr an automount?
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Joe Bussell
Sent: Wednesday, July 05, 2006 12:19 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] PERL interface trouble
Thank you! I have mode some progress. The fact that my fonts/
directory was not readable escaped my notice. The msGetErrorString
function provided that data right away.
I have still have some undesired behavior however. I added
$img->save( $outfile );
carp mapscript::msGetErrorString("\n");
And it indicates that my image file is not openable for write. I have
verified that the entire directory chain indicated in the message is
world writable. Is there something else that I need to do?
[Mon Jul 3 15:52:17 2006] -e: Failure: msSaveImageGD(): Unable to
access file.
Unable to open file
/usr/routing/routes/Route1151967137028128.223.40.5.png for writing at
/usr/routing/perl/dwarp/mapdrawing.pm line 515
I changed my write directory to be a child of /tmp, and everything
worked out just fine. I verified that the directory permissions matched
and could not find any reference in my httpd.conf that would preclude
writing to a directory off of /usr. Any ideas as to why this is?
Joe Bussell
On Time Systems
Steve Lime wrote:
> You can get at the MapServer error stack with a call like:
> my $map = new mapscript::mapObj( $mapfile ) or
> That may help, or be something to try. I use perl MapScript with 4.8 and
the CVS version all the time with good results.
> Steve
>>>>Joseph Bussell <joe at OTSYS.COM> 6/30/2006 2:09:06 PM >>>
> Does anyone use the latest code with PERL Mapscript? If shp2img works
> with my mapfile, is there anything else I can do to understand why my
> new call for the mapObj fails?
> Joe Bussell
> On Time Systems
> Joseph Bussell wrote:
>>I have verified that shp2img constructs an image that derives form my
>>mapfile. This part looks good. My mapscript code was written for
>>4.4.2, but the one function that is failing does not appear to have
>>significantly changed. I am not getting past construction of the
>>basic mapObj from the mapfile. Specifically, the call to :
>>my $map = new mapscript::mapObj( $mapfile ) or carp "Could not create
>>mapscript object from mapfile: $mapfile";
>>produces the error message. I also went into mapscript.pm and added
>>debug code there to be sure I was using the correct module. The low
>>level call is producing an unusable result.
>>Joe Bussell
>>On Time Systems
>>Stephen Woodbridge wrote:
>>>Hi Joe,
>>>A couple of things.
>>>1) what version does you existing code work on?
>>>2) There are probably two areas that you will need to change
>>> a) the mapfile
>>> b) the perl
>>>I would start with using shp2img to make sure you mapfile can load.
>>>It will at least print errors that you can read.
>>>shp2img -m /path/to/file.map -o junk.png ...
>>>Once you can get an image then you will probably have more luck
>>>tracking down the various mapscript changes. These will depend on
>>>what version of mapscript your code was written for.
>>>-Steve W.
>>>>Greetings Listers,
>>>> It has been a while since I deployed a new Mapserver application.
>>>>I have been leaning on old source on an old box to get the work
>>>>done. I have been given a new server to set up for our Air Force
>>>>project and have had some issues with getting my code to work.
>>>>First of all I am using Mapscript ala PERL. I recognize that the
>>>>PERL interface has not been updated due to a lack of user interest,
>>>>but I am still partial to using it if it can still be done (mostly
>>>>since I will not have to rewrite my routing path functionality).
>>>> My problem is getting the actual mapObj to construct from my
>>>>mapfile. I have not been able to get any debug information our by
>>>>checking /tmp/mserrors, which used to work nicely in such cases.
>>>>All I get is an undefined reference. My code for construction is
>>>>simple:
>>>>create mapscript object from mapfile: $mapfile";
>>>>in my httpd.conf I define
>>>>MS_ERRORFILE /tmp/mserrors.txt
>>>>My mapfile exists and is very simple.
>>>>I am running:
>>>>CentOS release 4.3
>>>>AMD64, dual core machine
>>>>Apache/2.0.52
>>>>mapserver-4.8.3.tar.gz
>>>>perl, v5.8.5 built for x86_64-linux-thread-multi
>>>>Thank you for your time.
>>>>Joe Bussell
>>>>On Time Systems
