nothing shows up! no image or error?
Albert Anderson
bart_doggers at YAHOO.COM
Wed Jul 5 14:17:06 EDT 2006
This is what my map code look like
#This is Richland County Map Server
NAME "Richland"
SIZE 800 600
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
SHAPEPATH "/home/mapdata/"
EXTENT -97.502192 45.947754 -96.330315 46.826661
WEB
TEMPLATE '/var/www/htdocs/richland.html'
IMAGEPATH '/var/www/htdocs/tmp'
IMAGEURL '/tmp/'
END
LAYER
NAME "Richland"
STATUS default
TYPE polygon
DATA "RICH_bndy"
PROJECTION "init=epsq:26914"
END
END
END
I get this error now msProcessProjection(): Projection library error. no system list, errno: 2 ? What does that mean? How can I fix it?
Albert
Brock Anderson <banders at refractions.net> wrote: Albert,
For each layer it's important to tell mapserver which projection your
data is stored in. In your case:
LAYER
PROJECTION
"init=epsg:26914"
END #PROJECTION
END #LAYER
The epsg code 26914 represents "NAD83 / UTM zone 14N". I think that's
what you're looking for.
Brock
Albert Anderson wrote:
> Hi,
> I was using a projection file UTM Zone 14n Nad_83. Then I switch to an
> unprojective file and I saw my data show up. What would be the first
> best step for setting a projection file?
> Thanks
> Albert
> */"Fawcett, David" /* wrote:
> You may want to take a look at your extent.
> Do you really intend to show a primarily empty stretch of the
> northern Atlantic Ocean (apologies to Canary Islanders...)?
> You are telling MapServer that your map area is contained within a
> box from 50 deg. west longitude to 10 deg. west longitude and 20
> to 90 degrees north latitude. If the name of your mapfile relates
> to the data, I am guessing that Richland County isn't in this box.
> Use ogrinfo or a desktop GIS app to look at the extent of your
> data. Also, the extent needs to be in the units of the spatial
> reference system that your data is in.
> David.
> -----Original Message-----
> *From:* UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Albert
> Anderson
> *Sent:* Wednesday, July 05, 2006 10:10 AM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* [UMN_MAPSERVER-USERS] nothing shows up! no image or
> error?
> Hi,
> I am making my own map file. It looks all right but when I
> click the button it doesnt show an image or any kind of errors.
> Here is my map code.
> NAME "Richland"
> SIZE 100 100
> IMAGETYPE JPEG
> EXTENT -50.00 20.00 -10.00 90.00
> WEB
> IMAGEURL '/tmp/'
> END
> LAYER
> NAME "Richland"
> STATUS default
> TYPE polygon
> DATA "RICH_bndy"
> CLASS
> STYLE
> COLOR 0 0 0
> END
> END
> END
> END
> here is my html code
Richland County MapServer>
> [input]
> [input]
> value="/home/mapdata/richland.map">
> [input]
> value="/var/www/htdocs/tmp/">
> I really dont know whats could be wrong. Maybe the extent of
> it? Can anyone help me?
> Thanks,
> Albert
> How low will we go? Check out Yahoo! Messengerâs low
> PC-to-Phone call rates.
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
Want to be your own boss? Learn how on Yahoo! Small Business.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060705/29723764/attachment.html
