a layer from multiple datasources (similar to mapguide's
secondary table)
Zhonghai Wang
zhonghaiw at GMAIL.COM
Thu Jul 6 03:39:20 EDT 2006
Hi Eduard,
AFAIK, it's not possible.
the ESRI Shapefile has its own attribute table, the *.dbf file, maybe you
can add some columns to the shape file dbf, this should be a possible
solution. and without oracle data your application will be faster.
kind regards
zhonghai
On 7/3/06, Eduard Witteveen <e.witteveen at hawarit.com> wrote:
> Hello list,
> How do use multiple datasources (oracle-database-table and
> esri-shapefile) in the same layer?
> I want to give colors based upon the values defined in oracle, and also
> specify a filter on the dataset in oracle. The shape of the area's is
> stored in the esri-shapefile.
> Both the oracle database and shape file's have the same value in their
> data, so this should be used for the reference.
> I looked at "ogr-join", but i'm not sure if it is the tool for me?
> Ing. Eduard Yeb Witteveen Software Engineer
> Hawar Information Technology bv lid Dijkoraad Groep
> De Wymerts 7 8701 WT Bolsward
> Tel: +31 (0)515 570333 Fax: +31 (0)515 570335
> http://www.hawarit.com/ nl_NL fy_NL en_US
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060706/99e777b3/attachment.html
