WMS 1.3.0 in MapServer?
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Jul 7 09:53:40 EDT 2006
Hi Barend,
I don't know of any such plans (unfortunately).
The big caveat is as I understand it that PROJ.4 currently has no way to
determine the sequence of axes for a projection, and this is needed for
WMS 1.3. In the projection WKT this information is not stored, so an
application would need to check the EPSG database e.g.
I am sure Frank will be able to comment on this more.
Wrt other changes, I can name a few:
1) ScaleHints have been replaced with
MinScaleDenominator/MaxScaleDenominator (so scale ratio)
2) LegendURL image sizes are now optional which is a good thing
Best regards,
Bart
Barend Köbben wrote:
>Does anybody know if ther are plans for MapServer to be WMS 1.3.0 compatible?
>When reading the spec I find it difficult to see where ther are changes from 1.1.1 (other than it now being an ISO standrd also), and the OGC site is generally unhelpful, even in finding the answer to that obvious question...
>Barend Köbben
>International Institute for Geo-information
>Sciences and Earth Observation (ITC)
>PO Box 6, 7500AA Enschede (The Netherlands)
>ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
>>-----Original Message-----
>>From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
>>Sent: 07 July 2006 14:52
>>To: Barend Köbben
>>Subject: Re: [UMN_MAPSERVER-USERS] WMS Server and SLD
>>Hi there,
>> From what I understand, Joost wanted to use an SLD instated
>>of classes
>>on a wms *server* layer, so when a client access this server, the
>>rendering of this layer is done using the sld. I don't think It is
>>possible right now.
>>>> There is no current way to use sld instead of classes as
>>a styling
>>>>mechanism.
>>>? are you sure ?
>>>I have Mapserver instances that have no CLASS definitions
>>in the LAYERs and I call them with a URL that has
>>&SLD=http://myserver/somesld.xml in the Querystring. Works fine...
>>>Barend Köbben
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax: (613) 565-0925
OSGIS, Open Source GIS
http://www.osgis.nl
