WMS 1.3.0 in MapServer?
Barend Köbben kobben at ITC.NL
Fri Jul 7 09:46:15 EDT 2006
Does anybody know if ther are plans for MapServer to be WMS 1.3.0 compatible?
When reading the spec I find it difficult to see where ther are changes from 1.1.1 (other than it now being an ISO standrd also), and the OGC site is generally unhelpful, even in finding the answer to that obvious question...
Barend Köbben
International Institute for Geo-information
Sciences and Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: 07 July 2006 14:52
> To: Barend Köbben
> Subject: Re: [UMN_MAPSERVER-USERS] WMS Server and SLD
> Hi there,
>  From what I understand, Joost wanted to use an SLD instated
> of classes
> on a wms *server* layer, so when a client access this server, the
> rendering of this layer is done using the sld.  I don't think It is
> possible right now.
> Barend Köbben wrote:
> >>  There is no current way to use sld instead of classes as
> a styling
> >>mechanism.
> > ? are you sure ?
> > I have Mapserver instances that have no CLASS definitions
> in the LAYERs and I call them with a URL that has
> &SLD=http://myserver/somesld.xml in the Querystring. Works fine...
> > Barend Köbben
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
