error during make (mac os x)
Andrew Wiens
awiens at GMAIL.COM
Tue Jul 11 21:06:18 EDT 2006
Thanks William,
That worked wonderfully.
Concerning the Ruby Mapscript, I wouldn't know where to start trying to
build it from the mapscriptvars and libmap.a files. I'm very new to the Mac
environment and *nix environment in general.
I had already built and installed the libraries required for Mapserver, but
using your precompiled libraries sounds like a much more efficient solution
so I'll be doing that in the future.
Thanks again,
--Andy
On 7/12/06, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Known problem with Xcode 2.2+. In makefile.in change the LD line to:
> LD=@CXX@
> then reconfigure and make.
> Also, you can reuse my Graphics Libs and GIS Libs so you don't have
> to build that whole mess. Edit configure (grep find and replace in
> BBEdit or TextWrangler works great for this) and replace all (using
> word/case sensitive):
> (lib(png|jpeg|gd|proj|pdf|Xpm)).a
> with:
> \1.dylib
> And specify locations for all libraries in configure, since they're
> not in 'normal' locations that would be found automatically.
> ./configure --with-zlib=/usr --with-proj=/usr/local/gislibs --with-
> gdal=/usr/local/gislibs/bin/gdal-config --with-ogr --with-gd=/usr/
> local/graphicslibs --with-png=/usr/local/graphicslibs --with-jpeg=/
> usr/local/graphicslibs --with-freetype=/usr/local/graphicslibs/bin/
> freetype-config --with-xpm=/usr/local/graphicslibs --with-pdf=/usr/
> local/graphicslibs --with-ming=/usr/local/graphicslibs --with-geos=/
> usr/local/gislibs/bin/geos-config --with-postgis=/usr/local/pgsql/bin/
> pg_config --with-wfs --with-wcs --with-wfsclient --with-wmsclient --
> with-curl-config=/usr/local/baselibs/bin/curl-config
> I probably won't do a Ruby MapScript binary for my Mac OS X package,
> more stuff to install just to get it going. I think I tried
> installing SWIG a while back with not much luck, but it's probably
> improved now.
> One possibility just occurred to me to simplify things - many (all?)
> of the mapscript variations use the mapscriptvars file generated
> during the mapserv build, and libmap.a of course. I could add those
> to the package so all you would need to do is the Ruby build. If you
> would like to try this, let me know.
> On Jul 11, 2006, at 4:53 PM, Andrew Wiens wrote:
> > Hello. I've been trying to build mapserver on Mac OS X 10.4.7
> > (Intel), but have had no success. I don't think that the available
> > precompiled binaries will work for my application as I need the
> > Ruby Mapscript libraries. I've included the error and configure
> > output below. Any help solving the problem would be greatly
> > appreciated. Thanks. --Andy
> > I'm getting the following error:
> > gcc -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DHAVE_VSNPRINTF -
> > DUSE_EPPL -DUSE_PROJ -DUSE_WMS_SVR -DUSE_GD_GIF -
> > DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -
> > DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_PDF -DUSE_OGR
> > -DUSE_GDAL -DUSE_GEOS -DUSE_ICONV -DUSE_POSTGIS -DUSE_THREAD -
> > DUSE_ZLIB -I/usr/local/include -I/usr/local/include -I/usr/
> > local/include -I/usr/local/pgsql/include -I/usr/local/
> > include shp2img.o -L. -lmap -L/usr/local/lib -lgd -ljpeg -
> > lfreetype -lpng -lz -L/usr/X11R6/lib -lXpm -lX11 -lpdf -ljpeg -
> > lfreetype -lpng -lz -L/usr/X11R6/lib -lXpm -lX11 -L/usr/local/lib -
> > lproj -ljpeg -L/usr/local/lib -lgdal -L/usr/local/pgsql/lib -
> > lpq -L/usr/local/lib -lgeos -lpthread -liconv -lz -lm -lstdc+
> > + -o shp2img
> > /usr/bin/ld: Undefined symbols:
> > __Unwind_Resume
> > collect2: ld returned 1 exit status
> > make: *** [shp2img] Error 1
> > My configuration configure options and output are as follows:
> > ./configure \
> > --mandir=/usr/local/share/man \
> > --with-threads \
> > --with-proj=/usr/local \
> > --with-gdal=/usr/local/bin/gdal-config \
> > --with-ogr=/usr/local/bin/gdal-config \
> > --with-gd=/usr/local \
> > --with-xpm=/usr/X11R6 \
> > --with-geos=/usr/local/bin/geos-config \
> > --with-postgis=/usr/local/pgsql/bin/pg_config \
> > --with-freetype=/usr/local/bin/freetype-config \
> > --with-httpd=/usr/sbin/httpd
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole. Now what
> does that remind me of? Ah, yes - life."
> - Marvin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060712/96ef46c0/attachment.html
