error during make (mac os x)
William Kyngesburye
woklist at KYNGCHAOS.COM
Tue Jul 11 21:41:16 EDT 2006
It *should* be as simple as dropping these files into the mapserver
source folder (no need to have it built) and following the
instructions for building the Ruby mapscript. I see two possible
problems:
- You would also have to install Postgres. Or edit the mapscriptvars
file.
- Since you're new to all this, did you get SWIG installed somehow?
The Ruby mapscript readme says you need that.
Otherwise rebuilding MapServer from scratch + Graphics Libs and GIS
Libs works well enough also.
On Jul 11, 2006, at 8:06 PM, Andrew Wiens wrote:
> Thanks William,
> That worked wonderfully.
> Concerning the Ruby Mapscript, I wouldn't know where to start
> trying to build it from the mapscriptvars and libmap.a files. I'm
> very new to the Mac environment and *nix environment in general.
> I had already built and installed the libraries required for
> Mapserver, but using your precompiled libraries sounds like a much
> more efficient solution so I'll be doing that in the future.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
