error during make (mac os x)
Andrew Wiens awiens at GMAIL.COM
Tue Jul 11 21:50:48 EDT 2006
That sounds really easy.  I'd be willing to give it a shot to see if it'd
work.
I was able to get swig and mapscript installed but am getting an error when
I try to test the installation with shp2img.  The error I'm getting is this:
dyld: NSLinkModule() error
dyld: Symbol not found: _intarray_setitem
  Referenced from: /usr/local/lib/ruby/site_ruby/1.8/i686-darwin8.6.1
/mapscript.bundle
  Expected in: flat namespace
Trace/BPT trap
Any ideas what the problem could be?
Thanks.
--Andy
On 7/12/06, William Kyngesburye <woklist at kyngchaos.com> wrote:
> It *should* be as simple as dropping these files into the mapserver
> source folder (no need to have it built) and following the
> instructions for building the Ruby mapscript.  I see two possible
> problems:
> - You would also have to install Postgres.  Or edit the mapscriptvars
> file.
> - Since you're new to all this, did you get SWIG installed somehow?
> The Ruby mapscript readme says you need that.
> Otherwise rebuilding MapServer from scratch + Graphics Libs and GIS
> Libs works well enough also.
> On Jul 11, 2006, at 8:06 PM, Andrew Wiens wrote:
> > Thanks William,
> > That worked wonderfully.
> > Concerning the Ruby Mapscript, I wouldn't know where to start
> > trying to build it from the mapscriptvars and libmap.a files.  I'm
> > very new to the Mac environment and *nix environment in general.
> > I had already built and installed the libraries required for
> > Mapserver, but using your precompiled libraries sounds like a much
> > more efficient solution so I'll be doing that in the future.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060712/63031b4d/attachment.html
