query string question
Steve Lime Steve.Lime at DNR.STATE.MN.US
Wed Jul 12 01:59:46 EDT 2006
You jave a couple of options:
  qstring: ('[str_type]' = 'AVE' or '[str_type]' = 'ST')
  qstring: ('[str_type]' in ('AVE','ST'))
  qstring: /AVE|ST/
The latter is probably the fastest. The first two shouldn't require a qitem although you might set it just to be safe even though the value won't be used.
Steve
>>> Albert Anderson <bart_doggers at YAHOO.COM> 07/11/06 11:34 AM >>>
Hi All,
 I have a question about ITEMNQUERY mode. I want to search for two different items at the same time like AVE and ST.
Map Mode: ITEMNQUERY       Query Layer:Roads
                                              Query Item:Str_type
                                             Query string:/AVE/
and that just brings up the AVE. So how do I get the AVE and ST load query.  What should the query string look like?  Can some help me.
Thanks,
Albert
Sneak preview the  all-new Yahoo.com. It's not radically different. Just radically better.
