AW: [UMN_MAPSERVER-USERS] Map Projections
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Fri Jul 14 16:42:31 EDT 2006
Hello Arnd,
Thank for for the reply. The main problem that i am having is i have some
datasets with a prime meridian at 0 degress and others that have a prime
meridian at 90 degrees and i need these raster datasets to line up. but when i
specify a map projection as:
PROJECTION
"proj=cc"
"lon_0=90w"
"ellps=WGS84"
"datum=WGS84"
END
and a layer projection as:
PROJECTION
"proj=cc"
"lon_0=0"
"ellps=WGS84"
"datum=WGS84"
END
Rather then the layer geting reprojected to the map projection I get a blank
image. I do however get a different map image of i just change the projection
name of the map file to some like: lcc or merc. But why am i getting a blank
image when i try to shift the prime meridian?
Thank you for any help you can provide,
-Ryan
Quoting Arnd Wippermann <arnd.wippermann at web.de>:
> Hello,
> Mapserver is capable of re-projecting. The projection of the layers (raster
> or vector data) can differ from the projection of the map. Your output comes
> in the map projection.
> Mit freundlichen Grüssen
> Arnd Wippermann
> http://gis.ibbeck.de/pinguinale/
> -----Ursprüngliche Nachricht-----
> I am having a bit of trouble re-projecting my data. When I specify the
> PROJECTION object in my map file as
> PROJECTION
> "proj=cc"
> "lon_0=0"
> "ellps=WGS84"
> "datum=WGS84"
> END
> Or
> PROJECTION
> "proj=cc"
> "lon_0=90"
> "ellps=WGS84"
> "datum=WGS84"
> END
> My image does not change, but the prime meridian should be changing
> locations from the center of the image to the far left. I also tried to
> specify the projection in the layer itself but still no change. Isnt
> MapServer capable of re-projecting the data regardless of the original
> projection?
