cant get my lavyers working w/my projection file
Pagurek,Debbie [NCR] Debbie.Pagurek at EC.GC.CA
Mon Jul 17 11:19:31 EDT 2006
If your other layers are not projected, you mean that they are in
'geographic'. You still need to set a projection object for them.
Try
PROJECTION
  "init=epsg:4326"
END
This is geographic with the datum set as WGS84. This might not be the
proper settings for your data - you could have another datum... anyway -
set this projection object in your mapfile to see if you can get it
working. What will happen is that Mapserver will project these layers on
the fly to match the projection in your MAP object.
D. Pagurek
  _____
From: Albert Anderson [mailto:bart_doggers at yahoo.com]
Sent: Monday, July 17, 2006 11:12 AM
To: Pagurek,Debbie [NCR]; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] cant get my lavyers working w/my
projection file
 I add a projection map file of richland county.  The other layers that
I have are unprojective files. The roads file is all the road in the
county.  Right now they are not catagorized. Thats the way the other
layers are.  I just want to get the projection file loaded which is and
also my layers which are not.
  Setting it to default didnt seem to work.
Thanks,
Albert
"Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> wrote:
	perhaps you could provide a bit more information to us. What is
the native projection of the roads, boundary line, and etc... layers? If
it isn't in the same projection as specified in your MAP object,
	PROJECTION
	  "init=epsg:26914"
	END
	then you also need to specify the projection in the layer
object.
	you also might want to try to put STATUS DEFAULT for the roads,
boundary etc and that way they will ALWAYS be ON. If status is set to ON
you have to make sure that your URL specifies layers=layername in order
for it to be on.
	Hope this helps,
	D. Pagurek
  _____
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
	Sent: Friday, July 14, 2006 4:58 PM
	To: MAPSERVER-USERS at LISTS.UMN.EDU
	Subject: [UMN_MAPSERVER-USERS] cant get my lavyers working w/my
projection file
	 I got my projection file working but I cant see to get my
layers working like roads, boundary line, and etc...  Can someone look
at my code and help me.  Thanks!
	---Codes-------
	<body>
	  <form method=POST action="/cgi-bin/mapserv">
	    <input type="submit" value="Click to initialize">
	    <input type="hidden" name="program" value="mapserv">
	    <input type="hidden" name="map"
value="/home/mapdata/richland.map">
	    <input type="hidden" name="mapext" value="626173.309834
5085113.091715 694065.960556 5176735.212592">
	    <input type="hidden" name="zoomsize" size="2" value="2">
	    <input type="hidden" name="layers" value="boundary roads
sections">
	  </form>
	 </body>
	</html>
	<input type="checkbox" name="layer" value="boundary"
[boundary_check]/>
	  County Boundary <br />
	  &nbsp;
	  <input type="checkbox" name="city" value="city" />
	  City Boundary <br />
	  &nbsp;
	  <input type="checkbox" name="township" value="township" />
	  Township<br />
	  &nbsp;
	  <input type="checkbox" name="layer" value="sections"
[sections_check]/>
	  Section Lines </span><br />
	  <br />
	  <font color="green"><span
class="style2">&nbsp;Land</span></font><br />
	  <span class="style4">
	  &nbsp;
	  <input type="checkbox" name="layer" value="parcels"
[parcels_check]/>
	  Parcels <br />
	  &nbsp;
	  <input type="checkbox" name="parcelslables"
value="parcelslables" />
	  Parcels Labels</span><br />
	  <br />
	  <font color="red"<span
class="style2">&nbsp;Transportation</span></font><br />
	  &nbsp;
	  <input type="checkbox" name="layer" value="roads"
[roads_check]/>
	  County/City Roads <br />
	  &nbsp;
	  <input type="checkbox" name="addresslabels"
value="addresslabels" />
	  Address Labels</span> </p>
	 <p class="style1"><font color="brown"><span
class="style2">&nbsp;Backgrounds</span></font><br />
	 &nbsp;
	 <input name="aerial" type="checkbox" id="aerial" value="aerial"
	  Aerial Photos</span></p>
	#This is Richland County Map Server
	NAME "Richland"
	SIZE 309 417
	UNITS miles
	IMAGECOLOR 255 255 255
	IMAGETYPE JPEG
	PROJECTION "init=epsg:26914"
	END
	SHAPEPATH "/home/mapdata/"
	EXTENT 626173.309834 5085113.091715 694065.960556 5176735.212592
	# Symbol for drawing fat lines
	SYMBOL
	     NAME "BigLine"
	     TYPE ELLIPSE
	     POINTS 1 1 END
	END
	# Symbol for drawing dashed lines
	SYMBOL
	     NAME "DashedLine"
	     TYPE ELLIPSE
	     POINTS 1 1 END
	     STYLE 10 10 END
	END
	# Symbol for drawing spots
	SYMBOL
	     NAME "Circle"
	     FILLED true
	     TYPE ellipse
	     POINTS 1 1 END
	END
	# Web object
	WEB
	  TEMPLATE '/var/www/htdocs/gismapserver_test_project_mod.html'
	  IMAGEPATH '/var/www/htdocs/tmp/'
	  IMAGEURL '/tmp/'
	END
	# Reference map
	REFERENCE
	     IMAGE "/home/mapdata/richland.gif"
	     SIZE 136 152
	     EXTENT -97.228391 45.907505 -96.628389 46.717217
	     STATUS ON
	     COLOR -1 -1 -1
	     OUTLINECOLOR 0 0 0
	END
	# Scalebar
	SCALEBAR
	     LABEL
	          COLOR 0 0 0
	          ANTIALIAS true
	          SIZE small
	     END
	     POSITION lr
	     INTERVALS 5
	     STATUS embed
	     SIZE 144 5
	     STYLE 0
	     UNITS MILES
	     BACKGROUNDCOLOR 0 255 0
	     COLOR 128 128 128
	     OUTLINECOLOR 0 0 255
	     TRANSPARENT off
	END
	LAYER
	    NAME "richland"
	    STATUS default
	    TYPE polygon
	    DATA "RICH_bndy"
	    END
	    CLASS
	      STYLE
	            COLOR 238 220 130
	      END
	   END
	END
	LAYER
	    NAME "boundary"
	    STATUS on
	    TYPE line
	    DATA "RC_boundary_05"
	    CLASS
	      STYLE
	            COLOR 0 0 0
	      END
	   END
	END
	LAYER
	    NAME "roads"
	    STATUS on
	    TYPE line
	    DATA "roads_shp"
	    CLASS
	      STYLE
	            COLOR 255 0 0
	      END
	   END
	END
	LAYER
	    NAME "sections"
	    STATUS on
	    TYPE line
	    DATA "RC_sections_05"
	    CLASS
	      STYLE
	            COLOR 255 130 171
	      END
	   END
	END
	LAYER
	    NAME "parecles"
	    STATUS on
	    TYPE line
	    DATA "RC_parcels_05"
	    CLASS
	      STYLE
	            COLOR 0 0 0
	      END
	   END
	END
	END
	__________________________________________________
	Do You Yahoo!?
	Tired of spam? Yahoo! Mail has the best spam protection around
	http://mail.yahoo.com
  _____
See the all-new, redesigned Yahoo.com. Check it out.
<http://us.rd.yahoo.com/evt=40762/*http://www.yahoo.com/preview>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060717/21dd0b9f/attachment.html
