GetFeatureInfo from Oracle: no coordinates
Arjen de Korte arjendk at GMX.NET
Mon Jul 17 11:20:29 EDT 2006
Hello Fernando and list,
Thank you for your reply.
The layers are drawn correctly when I do a GetMap request. So I get a
correct map image.
It makes no difference if I use NONE instead of RELATE; still no
coordinates in the GetFeatureInfo result.
Does anyone on this list have WMS GetFeatureInfo working correctly with
Oracle Locator?
Regards,
Arjen.
On Thu, 13 Jul 2006 09:06:04 -0300, Fernando Simon said:
> Hi Arjen,
>     Sorry for the delay to reply you.
>     It's a strange problem, because you can see the attributes but no
> the data, I'm not a WMS/WFS specialist and I will check if can be a
> WMS/WFS problem.
>     About the Oracle Spatial connection, can you check if the layer will
> be draw using Mapserver CGI directly? Another issue, I don't know if in
> Locator the RELATE with geodetic SRID will work correctly, can you try
> to define the NONE instead of RELATE?
>     Best regards.
> Fernando Simon
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada - Brazil
> http://www.univali.br/g10 - UNIVALI/CTTMAR
> Arjen de Korte wrote:
> > Hello Mapserver users,
> > I'm trying to get Mapserver to give me a GetFeatureInfo result from
> > Oracle. I do get an XML document back, with the attributes and bounding
> > box in it, but *without* the coordinates!
> > So I do get a valid XML response, starting with <msGMLOutput> and
> > followed by the bounding box (<gml:Box>) and the attributes, but it does
> > not contain feature coordinates like <gml:MultiPolygon>.
> > We are using MS4W 1.5.3 and Oracle 9i Locator (no Spatial extensions).
> > In the mapfile the layer is defined by:
> > LAYER
> >   NAME test1
> >   METADATA
> >    "ows_title" "Test 1"
> >    "gml_include_items" "all"
> >    "wms_extent" "0 300000 300000 600000"
> >   END
> >   PROJECTION
> >    "init=epsg:28992"
> >   END
> >   STATUS ON
> >   TYPE POLYGON
> >   MAXSCALE 50000
> >   CONNECTIONTYPE oraclespatial
> >   CONNECTION "adk/adk at domain"
> >   DATA "geometry from test1 using unique ID srid 90112 relate version
> >   9i"
> >   DUMP true
> >   TEMPLATE "../templates/rivers_query_header.html"
> >   TRANSPARENCY 50
> >   CLASS
> >    NAME "Test 1"
> >    COLOR 0 100 0
> >   END
> > END
> > This is the URL I use for the request:
> > http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/geolocator/service/out.map&service=WMS&version=1.1.1&request=GetFeatureInfo&srs=EPSG:28992&bbox=174800,604995,178736,607363&info_format=application/vnd.ogc.gml&layers=bebgeb,water,test1&query_layers=test1&x=280.999999999999&y=70&width=615&height=370
> > Does anybody have a suggestion how to fix this?
> > Regards,
> > Arjen.
