cant get my lavyers working w/my projection file
Fawcett, David David.Fawcett at STATE.MN.US
Mon Jul 17 11:22:06 EDT 2006
Your units are specified in miles, but your projection uses meters as
units.  You need to change your units to meters.
As Debbie suggested, I would set all of your layers to status default
for debugging purposes.
David.
	-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
	Sent: Monday, July 17, 2006 10:12 AM
	To: MAPSERVER-USERS at LISTS.UMN.EDU
	Subject: Re: [UMN_MAPSERVER-USERS] cant get my lavyers working
	 I add a projection map file of richland county.  The other
layers that I have are unprojective files. The roads file is all the
road in the county.  Right now they are not catagorized. Thats the way
the other layers are.  I just want to get the projection file loaded
which is and also my layers which are not.
	  Setting it to default didnt seem to work.
	Thanks,
	Albert
	"Pagurek,Debbie [NCR]" <Debbie.Pagurek at EC.GC.CA> wrote:
		perhaps you could provide a bit more information to us.
What is the native projection of the roads, boundary line, and etc...
layers? If it isn't in the same projection as specified in your MAP
object,
		PROJECTION
		  "init=epsg:26914"
		END
		then you also need to specify the projection in the
layer object.
		you also might want to try to put STATUS DEFAULT for the
roads, boundary etc and that way they will ALWAYS be ON. If status is
set to ON you have to make sure that your URL specifies layers=layername
in order for it to be on.
		Hope this helps,
		D. Pagurek
		Sent: Friday, July 14, 2006 4:58 PM
		Subject: [UMN_MAPSERVER-USERS] cant get my lavyers
		 I got my projection file working but I cant see to get
my layers working like roads, boundary line, and etc...  Can someone
look at my code and help me.  Thanks!
		---Codes-------
		<body>
		  <form method=POST action="/cgi-bin/mapserv">
		    <input type="submit" value="Click to initialize">
		    <input type="hidden" name="program" value="mapserv">
		    <input type="hidden" name="map"
value="/home/mapdata/richland.map">
		    <input type="hidden" name="mapext"
value="626173.309834 5085113.091715 694065.960556 5176735.212592">
		    <input type="hidden" name="zoomsize" size="2"
value="2">
		    <input type="hidden" name="layers" value="boundary
roads sections">
		  </form>
		 </body>
		</html>
		<input type="checkbox" name="layer" value="boundary"
[boundary_check]/>
		  County Boundary <br />
		  &nbsp;
		  <input type="checkbox" name="city" value="city" />
		  City Boundary <br />
		  &nbsp;
		  <input type="checkbox" name="township"
value="township" />
		  Township<br />
		  &nbsp;
		  <input type="checkbox" name="layer" value="sections"
[sections_check]/>
		  Section Lines </span><br />
		  <br />
		  <font color="green"><span
class="style2">&nbsp;Land</span></font><br />
		  <span class="style4">
		  &nbsp;
		  <input type="checkbox" name="layer" value="parcels"
[parcels_check]/>
		  Parcels <br />
		  &nbsp;
		  <input type="checkbox" name="parcelslables"
value="parcelslables" />
		  Parcels Labels</span><br />
		  <br />
		  <font color="red"<span
class="style2">&nbsp;Transportation</span></font><br />
		  &nbsp;
		  <input type="checkbox" name="layer" value="roads"
[roads_check]/>
		  County/City Roads <br />
		  &nbsp;
		  <input type="checkbox" name="addresslabels"
value="addresslabels" />
		  Address Labels</span> </p>
		 <p class="style1"><font color="brown"><span
class="style2">&nbsp;Backgrounds</span></font><br />
		 &nbsp;
		 <input name="aerial" type="checkbox" id="aerial"
value="aerial" />
		  Aerial Photos</span></p>
		#This is Richland County Map Server
		NAME "Richland"
		SIZE 309 417
		UNITS miles
		IMAGECOLOR 255 255 255
		IMAGETYPE JPEG
		PROJECTION "init=epsg:26914"
		END
		SHAPEPATH "/home/mapdata/"
		EXTENT 626173.309834 5085113.091715 694065.960556
5176735.212592
		# Symbol for drawing fat lines
		SYMBOL
		     NAME "BigLine"
		     TYPE ELLIPSE
		     POINTS 1 1 END
		END
		# Symbol for drawing dashed lines
		SYMBOL
		     NAME "DashedLine"
		     TYPE ELLIPSE
		     POINTS 1 1 END
		     STYLE 10 10 END
		END
		# Symbol for drawing spots
		SYMBOL
		     NAME "Circle"
		     FILLED true
		     TYPE ellipse
		     POINTS 1 1 END
		END
		# Web object
		WEB
		  TEMPLATE
'/var/www/htdocs/gismapserver_test_project_mod.html'
		  IMAGEPATH '/var/www/htdocs/tmp/'
		  IMAGEURL '/tmp/'
		END
		# Reference map
		REFERENCE
		     IMAGE "/home/mapdata/richland.gif"
		     SIZE 136 152
		     EXTENT -97.228391 45.907505 -96.628389 46.717217
		     STATUS ON
		     COLOR -1 -1 -1
		     OUTLINECOLOR 0 0 0
		END
		# Scalebar
		SCALEBAR
		     LABEL
		          COLOR 0 0 0
		          ANTIALIAS true
		          SIZE small
		     END
		     POSITION lr
		     INTERVALS 5
		     STATUS embed
		     SIZE 144 5
		     STYLE 0
		     UNITS MILES
		     BACKGROUNDCOLOR 0 255 0
		     COLOR 128 128 128
		     OUTLINECOLOR 0 0 255
		     TRANSPARENT off
		END
		LAYER
		    NAME "richland"
		    STATUS default
		    TYPE polygon
		    DATA "RICH_bndy"
		    END
		    CLASS
		      STYLE
		            COLOR 238 220 130
		      END
		   END
		END
		LAYER
		    NAME "boundary"
		    STATUS on
		    TYPE line
		    DATA "RC_boundary_05"
		    CLASS
		      STYLE
		            COLOR 0 0 0
		      END
		   END
		END
		LAYER
		    NAME "roads"
		    STATUS on
		    TYPE line
		    DATA "roads_shp"
		    CLASS
		      STYLE
		            COLOR 255 0 0
		      END
		   END
		END
		LAYER
		    NAME "sections"
		    STATUS on
		    TYPE line
		    DATA "RC_sections_05"
		    CLASS
		      STYLE
		            COLOR 255 130 171
		      END
		   END
		END
		LAYER
		    NAME "parecles"
		    STATUS on
		    TYPE line
		    DATA "RC_parcels_05"
		    CLASS
		      STYLE
		            COLOR 0 0 0
		      END
		   END
		END
		END
		__________________________________________________
		Do You Yahoo!?
		Tired of spam? Yahoo! Mail has the best spam protection
around
		http://mail.yahoo.com
	See the all-new, redesigned Yahoo.com. Check it out.
<http://us.rd.yahoo.com/evt=40762/*http://www.yahoo.com/preview>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060717/cc047880/attachment.html
