ruby mapscript on mac os x
Andrew Wiens
awiens at GMAIL.COM
Mon Jul 17 14:51:24 EDT 2006
Thanks Howard. I got around the problem by installing an older version of
swig. Is this a sufficient workaround?
--Andy
On 7/18/06, Howard Butler <hobu at iastate.edu> wrote:
> Andrew,
> It appears that Ruby is also affected by the method renaming bugaboo
> (details about this can be found here
> <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1815>). I updated
> the check in CVS HEAD to look for Ruby as well as Python. None of
> these changes are in the 4.8 branch.
> Howard
> At 02:31 PM 7/12/2006, Andrew Wiens wrote:
> >------=_Part_12344_19872034.1152732661648
> >Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> >Content-Transfer-Encoding: 7bit
> >Content-Disposition: inline
> >Hello. I'm trying to get Ruby Mapscript setup to run on my mac (os x
> >10.4.7Intel). It looks like it's building correctly, but when I try
> >to run the
> >shp2img program from the examples directory, I get the following error:
> >dyld: NSLinkModule() error
> >dyld: Symbol not found: _intarray_setitem
> > Referenced from: /usr/local/lib/ruby/site_ruby/1.8/i686-darwin8.6.1
> >/mapscript.bundle
> > Expected in: flat namespace
> >Trace/BPT trap
> >I've reinstalled SWIG to make sure there were no errors during that
> process
> >and it looked like it installed properly. Any ideas what I should try
> next?
> >Thanks,
> >--Andy
> >Content-Type: text/html; charset=ISO-8859-1
> >(os x 10.4.7 Intel). It looks like it's building correctly,
> >but when I try to run the shp2img program from the examples
> ><br><br>dyld: NSLinkModule() error<br>dyld: Symbol not found:
> >_intarray_setitem<br> Referenced from:
> >/usr/local/lib/ruby/site_ruby<div>/1.8/i686-darwin8.6.1
> /mapscript.bundle<br>
> >Expected in: flat namespace<br><br>Trace/BPT trap
> ><br><br>I've reinstalled SWIG to make sure there were no errors
> >during that process and it looked like it installed properly.
> >Any ideas what I should try next?<br><br>Thanks,<br>--Andy<br></div><br>
> >------=_Part_12344_19872034.1152732661648--
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060718/e370d4c1/attachment.html
