ruby mapscript on mac os x
Howard Butler
hobu at IASTATE.EDU
Mon Jul 17 15:02:04 EDT 2006
Probably, although someone with a lot more ruby+swig experience than
myself would probably be able to expound on reasons why you want to
use newer swig versions if you're doing ruby. I think there were a
number of memory management-related fixes plus some other
improvements. If things seem to do what you need them to do with
1.3.27, I don't really think there is a compelling reason to switch.
Howard
At 01:51 PM 7/17/2006, Andrew Wiens wrote:
>Thanks Howard. I got around the problem by installing an older version of
>swig. Is this a sufficient workaround?
>--Andy
