Problem with the mailing list (Rejected posting to
MAPSERVER-USERS@LISTS.UMN.EDU)
Tamas Szekeres
szekerest at GMAIL.COM
Mon Jul 17 17:09:32 EDT 2006
When posting a message using the WEB reply method the message text is
replaces with:
"DD: MESSAGE"
And i get the following reply:
-----Original Message-----
From: University of Minnesota LISTSERV Server (14.3)
[mailto:LISTSERV at LISTS.UMN.EDU]
Sent: Monday, July 17, 2006 11:00 PM
To: Tamas Szekeres
Subject: Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
Your message is being returned to you unprocessed because it appears to
have
already been distributed to the MAPSERVER-USERS list. That is, a message
with
identical text (but possibly with different mail headers) has been posted
to
the list recently, either by you or by someone else. If you have reason
to
resend this message to the list (for instance because you have been notified
of
a hardware failure with loss of data), please alter the text of the message
in
some way and resend it to the list. Note that altering the "Subject:" line
or
adding blank lines at the top or bottom of the message is not sufficient;
you
should instead add a sentence or two at the top explaining why you
are
resending the message, so that the other subscribers understand why they
are
getting two copies of the same message.
Can anyone explain this behaviour. It also applies to the mapserver-dev
list.
Thanks,
Tamas
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: 2006.07.14.
