Looking for an OGC Compliant WFS/WCS Server
Shoaib Burq
hydromap at GMAIL.COM
Wed Jul 19 05:22:23 EDT 2006
John, from the little bit of experiance I have of WCS -- i found
Mapscript support for WCS somewhat lacking. I believe this is being
addressed for future releases. Mapserver-CGI is probably the way to
go. Someone can correct me if I haven't kept up-to-date.
cheers
Shoaib
> > Good Afternoon All,
> > I would like to use a WFS and WCS server as the front end for
> > a software
> > application we have that encodes our data in GML3.1.1. From
> > what I have
> > read on this list, it seems like MapServer is capable of
> > acting as a WFS
> > and WCS server. Is that correct?
> Correct. OGC:WFS 1.0.0 (serving GML2 and GML3 level 0), and OGC:WCS
> 1.0.0.
> > Is there any reason why it
> > wouldn't
> > be a good approach to use MapServer solely as a WFS and WCS
> > servers? If
> > this plan seems reasonable, where would you suggest I turn to
> > learn how
> > to implement these features of the MapServer?
> MapServer is flexible enough to act in many modes e.g. CGI mode as well
> as various OGC Web Services.
> For learning resources, check out the OGC howtos on
> http://mapserver.gis.umn.edu/docs. The MapServer OGC Web Services
> Workshop (http://devgeo.cciw.ca/ms_ogc_workshop/index.html) also
> provides a good tutorial and examples on getting up to speed on
> supporting OGC specifications in MapServer.
> > In advance, thanks for your help.
> > John
> > By the way, if this message duplicates an earlier post I sent, please
> > pardon the extra mail. I got the following message, but
> > never saw "the
> > original message" show up on the list.
> > Your message is being returned to you unprocessed because
> > it appears
> > to have
> > already been distributed to the MAPSERVER-USERS list. That is, a
> > message with
> > identical text (but possibly with different mail headers) has been
> > posted to
> > the list recently, either by you or by someone else. If you have
> > reason to
> > resend this message to the list (for instance because you have been
> > notified of
> > a hardware failure with loss of data), please alter the text of the
> > message in
> > some way and resend it to the list. Note that altering the
> > "Subject:"
> > line or
> > adding blank lines at the top or bottom of the message is not
> > sufficient; you
> > should instead add a sentence or two at the top
> > explaining why
> > you are
> > resending the message, so that the other subscribers
> > understand why
> > they are
> > getting two copies of the same message.
