mapserv not following extents?
xslove
xslove at CENTRUM.CZ
Wed Jul 19 05:49:18 EDT 2006
Hi, I have similar problem. I need to draw map with ratio 1:1.5 (my data has
WGS-84 coords), so I specify extent little smaller for Y axis. When I call
mapserv via cgi request, it is drawn correct. But when I use java code for
mapscript, extent for Y axis is ignored, recomputed and image has ratio 1:1.
Do you know about any solution?
Thanks very much
Radim
View this message in context: http://www.nabble.com/Re%3A-mapserv-not-following-extents--tf1644493.html#a5393392
Sent from the Mapserver - User forum at Nabble.com.
