Eclipse MapServer libmapscript.so: cannot open shared object file
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Wed Jul 19 12:16:16 EDT 2006
When trying to create a java application using eclipse i get the following
error:
java.lang.UnsatisfiedLinkError: libmapscript: libmapscript.so: cannot open
shared object file: No such file or directory
Here is my code:
import edu.umn.gis.mapscript.*;
import java.io.*;
public class HelloServlet {
public static void main(String[] args) {
System.loadLibrary("mapscript");
mapObj map;
imageObj image;
map=new mapObj("/var/www/html/mapserver/htdocs/display.map");
map.setProjection("init=epsg:4326");
image=map.draw();
image.save("test.png",map);
