Eclipse MapServer libmapscript.so: cannot open shared object
file
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Wed Jul 19 12:21:52 EDT 2006
Quoting Ryan Ollerenshaw <ollerery at engr.orst.edu>:
> When trying to create a java application using eclipse i get the following
> error:
> java.lang.UnsatisfiedLinkError: libmapscript: libmapscript.so: cannot open
> shared object file: No such file or directory
I have the library libmapscript.so saved at /home/ryan/workspace/mapscript_test
and I have tried setting my LD_LIBRARY_PATH using:
export LD_LIBRARY_PATH=/home/ryan/workspace/mapscript_test
But no luck, I have also tried adding the following to eclipse program
arguments:
-Djava.library.path=/home/ryan/workspace/mapscript_test/
But still no luck. Sorry i am new to eclipse to any help would be great.
> Here is my code:
> import edu.umn.gis.mapscript.*;
> import java.io.*;
> public class HelloServlet {
> public static void main(String[] args) {
> System.loadLibrary("mapscript");
> mapObj map;
> imageObj image;
> map=new mapObj("/var/www/html/mapserver/htdocs/display.map");
> map.setProjection("init=epsg:4326");
> image=map.draw();
> image.save("test.png",map);
