MapServer Java?
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Thu Jul 20 02:42:48 EDT 2006
You could also use a jsp (which in fact is a special type of servlet).
The tutorial from Sun's java site will help you to get started with
both of them (and much more):
http://java.sun.com/j2ee/1.4/docs/tutorial/doc/
Good luck,
Umberto
On 7/20/06, Ryan Ollerenshaw <ollerery at engr.orst.edu> wrote:
> I was able to create a java program which uses java mapscript, but now how do i
> get that program to run on my server so clients can access it.  It seems like a
> java Servlet is the way to go but i cant find any good tutorials on how to get
> started.  I know what the code looks like for a servelt (example below) but
> once i have that written where do i put it? do i need to install anything else
> to get it to run?  I am running Apache on fedora core 5.
> Servelt code:
> import java.io.*;
> import javax.servlet.http.*;
> import javax.servlet.*;
> public class Servlet_test extends HttpServlet {
>   public void doGet (HttpServletRequest req,HttpServletResponse res)
>     throws ServletException, IOException
>     PrintWriter out = res.getWriter();
>     out.println("Hello, world!");
>     out.close();
