Mapserver returns blank pages
antti siukola
siukola.antti at GMAIL.COM
Thu Jul 20 02:50:23 EDT 2006
Hello again!
As an addition I also have a problem with turning off the
antialiasing. I have a polygon layer that has a label set and if I set
antialiasing to false it still gets antialiased. Other layers with
text work without antialising but this polygon label uses antialiasing
by default.
Cheers!
Antti S
On 7/20/06, antti siukola <siukola.antti at gmail.com> wrote:
> Hi!
> I added that patch and tried another one too but I still get blank
> pages, even if I set antialiasing to false. So it looks like there's
> something else broken. Antialiasing sure has something to do with it
> since the number of blank pages are multiplied if antialiasing is on.
> Cheers
> Antti S
> On 7/19/06, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> > are you using an official release of gd or the patched version. there's a
> > bug in gd that causes these symptoms exactly
> > > the patch is to add this near line 3035 of gd.c at the beginning of
> > > static void gdImageSetAAPixelColor(gdImagePtr im, int x,
> > int y, int
> > > color, int t)
> > > if(x<0||y<0||x>=im->sx||y>=im->sy)
> > > return;
> > cheers
> > On 7/19/06, antti siukola <siukola.antti at gmail.com > wrote:
> > > HI!
> > > I just found out that using antialiasing produces more or less all of
> > > the blank page returns that I have. Is the antialias style parameter
> > > limited only to TrueType fonts and Cartoline symbols? I have used it
> > > on vector layers but after setting it to false on these layers all
> > > blank pages seem to disappear.
> > > Antti S
> > > On 7/18/06, Matthew Perry <perrygeo at gmail.com> wrote:
> > > > On 7/18/06, antti siukola <siukola.antti at gmail.com > wrote:
> > > > > Hi!
> > > > > How do I set my projection? I mean I know that the projection of my
> > maps is
> > > > > VVJ , 24, 1016, 7, 24, 0, 1,-1.6, -6599998.7 but how do I set it so
> > > > > that mapserver understands it? Or how do even I understand it? ;)
> > > > Check out
> > http://mapserver.gis.umn.edu/docs/reference/mapfile/projection/
> > > > Matt Perry
> > > > http://www.perrygeo.net
