NQuery or Query with overlapping planning regulations
Manfred Meier m.meier at SPIEKERMANN.DE
Wed Jul 26 02:13:08 EDT 2006
Hello,
if your number of different regulations at the same time is small, you
could generate all info for these regulations and display them on the
same page in invisible div's or iframe's together with a javascript
powered selection menu for the user.
Surely there are problems with javascript, browser compatibility and so
on, but perhaps it's an idea.
Manfred
Carlo A. Bertelli (Charta s.r.l.) schrieb:
> Hello,
> we are working at the website of the will-be Urban Center for the
> municipality of Genova, Italy.
> By now we have a website with descriptions of public and private works
> which is driven by interactive maps.
> The prototype works fairly well, it is mainly cgi mapserver inside a
> simple php custom made page and is supposed to become a cms driven
> site that uses Kaistar (http://www.kaistar.org - a java based open
> source cms).
> I think the problem I'm going to explain could be easily solved in
> php, but we are not going to use php as a long run solution.
> The problem could be conceived as a conditional choice between query
> and nquery and it's due to the specific nature of the geographic data.
> We use maps to go from one page (about areas, or problems, or public
> plans, or projects) to another.
> If we have project data that describe new developments or complete
> redevelopments, the problem does not arise. We will have projects
> spread all around the town area that do not overlap, so when we click
> on one area we can easily direct the user to a new page (a simple
> template contains the reference to the relevant project).
> All seems to work well.
> But when we deal with planning regulationswe cannot always direct the
> user to a single page. Sometimes regulations overlap. We should have
> some logic (java based or, by now, php based) in between that:
> * shows a page to let the user decide what page to go when multiples
> pages (for multiple regulations) are possible;
> * directly goes to the selected page when the query outputs only one page.
> Do someone have a better representation of the problem or a clean
> solution for this problem?
> Just to understand what happens in the prototype, look at:
> http://civis.comune.genova.it/uc5_web/
> http://civis.comune.genova.it/uc5_web/interna.php?codp=RIGURB01_1
> works well. This is the case of redevelopment;
> http://civis.comune.genova.it/uc5_web/interna.php?codp=GEC_RECCS1
> does not work as supposed. Multiple regulations overlap here.
