Mapserver blank image
Alejandro Rico
jarg58 at GMAIL.COM
Wed Jul 26 12:41:53 EDT 2006
Hi Raymond
looking at your mapfile, i found in the data source part in the layer, that
you aren't using an identifier in the select statement, and mapserver need
it, so add the column name that identify your geometries and use the clause
USING UNIQUE column_name.
May be this can help
On 7/25/06, Raymond Marcil <raymond_marcil at dnr.state.ak.us> wrote:
> Hi,
> I'm using mapserver-4.8.4. Using debian linux w/apache 1.3. Mapserver
> hits oracle spatial 9i (observed via tcpdump) and renders a blank image.
> I suspect a configuration issue. See attached gis.map. Adapted from
> demonstration demo.map. Any ideas/suggestions appreciated.
> Thanks, Ray
> Raymond E. Marcil
> Analyst/Programmer IV
> Land Records Information Section
> Alaska Department of Natural Resources
> 550 West 7th., #706, Anchorage, AK 99501
> Ph: (907)269-8855 / Fax: (907)269-8911
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 600 600
> # Anchorage: lat: 61d 13m N
> # long: 149d 52' W
> # Alaska latitude (y): 51-71
> # longitude (x): 129-187
> # EXTENT [minx] [miny] [maxx] [maxy]
> # EXTENT -71.53179836 -41.29253644 -71.14854968 -41.04421467
> EXTENT -180 -90 180 80
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> CONFIG "PROJ_LIB" "/usr/local/share/proj/"
> # you may need to change this to match your MapServer build
> IMAGETYPE PNG
> # Start of web interface definition (including WMS enabling metadata)
> WEB
> LOG /tmp/mapserver.log
> HEADER gis_header.html
> TEMPLATE gis.html
> FOOTER gis_foot.html
> IMAGEPATH "set in gis.html"
> IMAGEURL "set in gis.html"
> METADATA
> WMS_TITLE "UMN MapServer Itasca Demo"
> WMS_ABSTRACT "This is the UMN MapServer demonstration application for
> Itasca County located in north central Minnesota."
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://localhost/itasca/gis.html"
> WMS_SRS "EPSG:26915"
> END
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> # Start of reference map
> REFERENCE
> #IMAGE graphics/reference.png
> IMAGE graphics/alaska.gif
> SIZE 120 120
> STATUS ON
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 255 255 255
> SIZE tiny
> END
> STYLE 1
> SIZE 80 2
> COLOR 255 255 255
> UNITS MILES
> INTERVALS 1
> TRANSPARENT TRUE
> STATUS TRUE
> END
> # Start of symbol definitions (we're only using a few)
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
> END
> # Start of layer definitions
> # Define oracle spatial.
> LAYER
> NAME "coast"
> DEBUG ON
> TYPE POLYGON
> STATUS DEFAULT
> CONNECTIONTYPE oraclespatial
> CONNECTION "mapper_web/***@dnrdev1"
> #DATA "GEOM FROM MAPPER.MV_COAST_SIMPLE USING SRID 1000000"
> DATA "GEOM FROM (SELECT GEOM FROM MAPPER.MV_COAST_SIMPLE) USING SRID
> 1000000"
> DUMP TRUE
> CLASS
> NAME "coast"
> STYLE
> OUTLINECOLOR 0 0 0
> COLOR 0 128 128
> END
> TEMPLATE "template.html"
> COLOR 0 128 128
> END
> END
> END # Map File
Alejandro Rico
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060726/34a53645/attachment.html
