fastest way to convert lon-lat to points
Roberto Bianconi roberto.bianconi at GMAIL.COM
Wed Jul 26 13:39:15 EDT 2006
On 7/20/06, P Kishor <punkish at eidesis.org> wrote:
> On 7/20/06, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> > Puneet: Why is speed such a big deal or will you be doing this often?
> I will be doing this a few times a year (so, often, although not
> necessarily often enough), but this portion is only a part of a longer
> process. So, I have to optimize each step as much as I can for overall
> better rate of return.
> > Anyway, if it were me I'd just write a quick MapScript script using
> > perl. Create a new shapefileObj, a new XBase table, open the file and
> > start looping. The loop itself should have like 3 lines of code. The
> > whole script should be about 15...
suppose your csv file is made of these records:
12.500,41.890,790380
12.530,41.890,790480
In Perl you might go like this. Actually a bit more than 15 lines, but
you can reduce it if you like :))
use mapscript;
use XBase;
my $csv = 'dummy.csv';
my $outfile = 'dummy_out'; # any name with no extension
my $table = XBase->create(name => "$outfile.dbf",
                        field_names =>['X','Y','VALUE'],
                        field_types => ['N','N','N'],
                        field_lengths => [8,8,10],
                        field_decimals => [3,3,0]) or die XBase->errstr;
my $shapefile = new mapscript::shapefileObj($outfile,1) or die;
open (CSV,"<$csv") or die "Cannot open $csv: $!\n";
my @lines = <CSV>;
close (CSV);
my $i = -1;
foreach (@lines) {
    chomp;
    my @rec = split /,/;
    my ($x,$y,$value) = @rec;
    $i++;
    $table->set_record($i, at rec) or die XBase->errstr;
    my $point = new mapscript::pointObj();
    $point->setXY($x,$y);
    my $line = new mapscript::lineObj();
    $line->add($point);
    my $shape = new mapscript::shapeObj();
    $shape->add($line);
    $shapefile->add($shape);
$shapefile = '';
ciao
Roberto
