UDig & Mapserver WFS
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Wed Jul 26 13:49:01 EDT 2006
I have also been having a problem with uDIG and WFS which is the GML returned
from my WFS seems to be good (all the data is present), but uDIG does not
output any data about my features when using the Information tool.
here is part of the XML returned using the HTTP request:
http://neuron/cgi-bin/mapserv?map=../html/mapserver/htdocs/webservices.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=hrsc_nd&
<wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
http://mapserver.gis.umn.edu/mapserver
http://neuron/cgi-bin/mapserv?map=../html/mapserver/htdocs/webservices.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=hrsc_nd&OUTPUTFORMAT=XMLSCHEMA">
<gml:boundedBy>
<gml:Box srsName="EPSG:4326">
<gml:coordinates>-180.000000,-79.029000 180.000000,83.969300</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<ms:hrsc_nd>
<gml:boundedBy>
<gml:coordinates>87.715900,-48.050500 92.044000,-31.895800</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<ms:msGeometry>
<gml:Polygon srsName="EPSG:4326">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>
87.715900,-47.952400 87.748000,-47.752900 87.809800,-47.356500
91.455800,-34.774400 91.461900,-34.915400 87.715900,-47.952400
</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ms:msGeometry>
<ms:gid>1</ms:gid>
<ms:id>4</ms:id>
<ms:filename>h0010_0000_nd2.img</ms:filename>
<ms:detec_id>MEX_HRSC_NADIR</ms:detec_id>
<ms:releas_i>0001</ms:releas_i>
<ms:revis_id>0000</ms:revis_id>
<ms:start_ti>2004-01-10T13:51:51.460Z</ms:start_ti>
<ms:max_res_>19.8</ms:max_res_>
</wfs:FeatureCollection>
Quoting "Bart van den Eijnden (OSGIS)" <bartvde at XS4ALL.NL>:
> I think your problem is with the schema (DescribeFeatureType refererence
> in the GML response).
> If I use:
http://ogc.midwestsurveys.com/geoserve/ms?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=capitals&OUTPUTFORMAT=XMLSCHEMA
> I don't get back the schema.
> capitals should be Capitals then it works.
> uDIG is very sensitive to such things.
> Best regards,
> Bart
> Angus Dickey wrote:
> >Hey List,
> >Has anybody tried using UDig as a client for a WFS service from Mapserver? I
> have mapserver running a WFS service that seems to produce fine GML, some
> other clients can connect correctly, but UDig always errors out.
> >I will post the actual error to the UDig list, but was hoping somebody might
> have some insight into whether this is a UDig or Mapserver problem.
> >For a sample mapserver response try this:
>http://ogc.midwestsurveys.com/geoserve/ms?SERVICE=WFS&version=1.0.0&request=getfeature&TYPENAME=capitals&OUTPUTFORMAT=gml2
> >Thanks,
> >~Angus
> OSGIS, Open Source GIS
> http://www.osgis.nl
