WMS time question
Gerry Creager gerry.creager at TAMU.EDU
Wed Jul 26 21:54:48 EDT 2006
I'm thinking land-use/land-cover changes over time.  While these could
be represented by a single consensus timestamp, having a period/interval
makes more sense.
As Bart mentioned, his data are for roads and have a valid from-to timeset.
As I recall WMS time series history, the requirement was for a single
timestamp and that's what got implemented.  GoMOOS, right?
gerry
Yewondwossen Assefa wrote:
> Bart,
> Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> looking through the Mapserver WMS time HOWTO I wondered one thing, it is
>> only possible to have 1 timeitem, a DB column which contains the
>> date/time. Ofcourse this is pretty okay for satellite images (in a
>> tileindex) which are taken every X days/months.
>> But what happens to road network segments (geometries in Oracle Spatial
>> for instance) which have a minimum date and a maximum date? So you
>> need to
>> specify 2 timeitems (one min and one max) for that. Was this use case
>> just
>> not implemented?
>  What would the min/max date represent : the valid time extents or
> simply 2 time fields on which we can do a query ?
> The wms request allows to  send a time value that is then compared to
> the value inside the timeitem. Would you expect to be able to compare
> the time request between the 2 timeitmes defined ?
>> Best regards,
>> Bart
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020  FAX 979.862.3983
MAIL:  AATLT, 3139 TAMU
Physical: 1700 Research Parkway, Suite 160,
College Station, TX 77843-3139
