3D Polygon
K S proxiroxp at YAHOO.GR
Thu Jul 27 07:54:36 EDT 2006
I have tried using TYPE POLYGON in this LAYER but mapserver keeps showing the error message:
  msDrawShapes() General error message. Only polygon shapes can be drawn using a POLYGON layer definition.
  I am using mapserver version 4.8.4 from the precompiled pack that is  distributed from maptools.org. I can use TYPE LINE for the LAYER  without getting any error but that doesn't result to the map I want to  show.Any ideas?
  Thank you for the response!
"Bart van den Eijnden (OSGIS)" <bartvde at xs4all.nl> έγραψε:  You should just use TYPE POLYGON. Note I think you need Mapserver 4.6 or
greater, best to try with the latest release (4.8.X).
Btw, Mapserver has a compile option determining whether or not it will
pick up Z and M values.
# If you want to use shape Z and M parameter this option must be set.
# It's OFF by default.
#USE_POINT_Z_M=-DUSE_POINT_Z_M
USE_POINT_Z_M=
Best regards,
Bart
K S wrote:
> Hello everybody,
>     I have a shapefile which is GEOMETRY:  3D POLYGON. How can i draw
> the layer for this shapefile. To be more specific what would be the
> TYPE of such a layer
> Thank you in advance
> Χρησιμοποιείτε Yahoo!
> Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την
> καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
> http://login.yahoo.com/config/mail?.intl=gr
OSGIS, Open Source GIS
http://www.osgis.nl
 Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060727/ebfd4392/attachment.html
