3D Polygon
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Thu Jul 27 07:59:35 EDT 2006
What does ogrinfo report on your shapefile? Can you send us the output?
Best regards,
Bart
> I have tried using TYPE POLYGON in this LAYER but mapserver keeps showing
> the error message:
> msDrawShapes() General error message. Only polygon shapes can be drawn
> using a POLYGON layer definition.
> I am using mapserver version 4.8.4 from the precompiled pack that is
> distributed from maptools.org. I can use TYPE LINE for the LAYER
> without getting any error but that doesn't result to the map I want to
> show.Any ideas?
> Thank you for the response!
> "Bart van den Eijnden (OSGIS)" <bartvde at xs4all.nl> Ýãñáøå: You should
> just use TYPE POLYGON. Note I think you need Mapserver 4.6 or
> greater, best to try with the latest release (4.8.X).
> Btw, Mapserver has a compile option determining whether or not it will
> pick up Z and M values.
> # If you want to use shape Z and M parameter this option must be set.
> # It's OFF by default.
> #USE_POINT_Z_M=-DUSE_POINT_Z_M
> USE_POINT_Z_M=
> Best regards,
> Bart
> K S wrote:
>> Hello everybody,
>> I have a shapefile which is GEOMETRY: 3D POLYGON. How can i draw
>> the layer for this shapefile. To be more specific what would be the
>> TYPE of such a layer
>> Thank you in advance
>> ×ñçóéìïðïéåßôå Yahoo!
>> ÂáñåèÞêáôå ôá åíï÷ëçôéêÜ ìçíý ìáôá (spam); Ôï Yahoo! Mail äéáèÝôåé ôçí
>> êáëýôåñç äõíáôÞ ðñïóôáóßá êáôÜ ôùí åíï÷ëçôéêþí ìçíõìÜôùí
>> http://login.yahoo.com/config/mail?.intl=gr
> OSGIS, Open Source GIS
> http://www.osgis.nl
