How to show high resolution image
Joe Bussell joe at OTSYS.COM
Thu Jul 27 16:04:29 EDT 2006
I have a high resolution snapshot of worldwide weather that I am
attempting to use in a similar manner.  The image looks real nice all by
itself, but when I pass it through my mapserver application the image
appears tiled.  Is this likely due to the number of colors in the
original?  Is there any special magic to getting native resolution using
the latest stable Mapserver?
Thanks,
Joe Bussell
On Time Systems
> Sarawut,
> Mapserver should display your image at it's original resolution if you zoomed
> in far enough. However, mapserver 3.6.x does not support 24bit color output.
> Maybe the degradation that you see is not the spatial resolution but a
> degradation in color? Mapservers dithering is not really sophisticated... You
> will get far better results if you scale down your original 24bit color
> landsat image to 8bit (using a color palet) and use that 8bit image in your
> map file. You could do that with tools like imagemagick or probably other
> image processing programs.
> Regards,
> Vincent Schut.
> On Wednesday 14 May 2003 09:41, Sarawut Ninsawat wrote:
>> > Dear all
>> > First I wish to show my Landsat image on mapserv 3.6 (RH8.0) with high
>> > quality as same as my original TIFF file.
>> > Even I set the minscale to only 5000. However,this is still not nice image
>> > but it can zoom to that extent. I think the reason is Pixel size of output
>> > image. How can I improve the resolution ?
>> > Best Regard
>> > Sarawut
>> > _______________________________________________
>> > Mapserver-users mailing list
>> > Mapserver-users at lists.gis.umn.edu
>> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> -- ______________________________________ Vincent Schut Sarvision B.V.
> Wageningen, The Netherlands www.sarvision.com
> _______________________________________________ Mapserver-users
> mailing list Mapserver-users at lists.gis.umn.edu
