3D Polygon
K S proxiroxp at YAHOO.GR
Thu Jul 27 16:08:53 EDT 2006
Sorry for the delay! Thanks for the response!
  Here is the report of ogrinfo for the shapefile. Supposed that the  precompiled version of mapserver doesn't support 3D polygon how can I  "enable" 3D polygons' support?
  Layer name: TownBlocks
  Geometry: 3D Polygon
  Feature Count: 8024
  Extent: (496798.420507, 3874382.779711) - (692235.890369, 3932301.842024)
  Layer SRS WKT:
  PROJCS["Greek_Grid",
      GEOGCS["GCS_GGRS_1987",
          DATUM["Greek_Geodetic_Reference_System_1987",
              SPHEROID["GRS_1980",6378137.0,298.257222101]],
          PRIMEM["Greenwich",0.0],
          UNIT["Degree",0.0174532925199433]],
      PROJECTION["Transverse_Mercator"],
      PARAMETER["False_Easting",500000.0],
      PARAMETER["False_Northing",0.0],
      PARAMETER["Central_Meridian",24.0],
      PARAMETER["Scale_Factor",0.9996],
      PARAMETER["Latitude_Of_Origin",0.0],
      UNIT["Meter",1.0]]
  OBJECTID: Integer (9.0)
  FID_?ώΆΎϊΎ: Integer (9.0)
  SDE_blockc: Real (19.11)
  PERIMETER: Real (19.11)
  TBLOCK_: Real (19.11)
  TBLOCK_ID: Real (19.11)
  ESYE_CODE: Integer (9.0)
  MATCH_: Integer (9.0)
  XBLOCK: Real (19.11)
  YBLOCK: Real (19.11)
  MUN_NAME: String (40.0)
  MUN_CODE: String (8.0)
  OT: String (12.0)
  TR_POP: Real (19.11)
  PER_POP: Real (19.11)
  NOIK: Real (19.11)
  HOUSES: Real (19.11)
  H_OWN: Real (19.11)
  H_REN: Real (19.11)
  H_KAT: Real (19.11)
  H_KEN: Real (19.11)
  H_KY_KA: Real (19.11)
  H_EXOH: Real (19.11)
  PER_MEN: Real (19.11)
  PER_WOM: Real (19.11)
  AGE14: Real (19.11)
  AGE1564: Real (19.11)
  AGE65: Real (19.11)
  YDR: Real (19.11)
  EDR: Real (19.11)
  H_PKEN: Real (19.11)
  H_PREN: Real (19.11)
  H_POWN: Real (19.11)
  H_PEXOH: Real (19.11)
  M_W_RAT: Real (19.11)
  NOIK_MESO: Real (19.11)
  POPDEN: Real (19.11)
  FID_LLNew_: Integer (9.0)
  Shape_Leng: Real (19.11)
  Shape_Ar_1: Real (19.11)
  Shape_Le_1: Real (19.11)
  Shape_Area: Real (19.11)
"Bart van den Eijnden (OSGIS)" <bartvde at XS4ALL.NL> έγραψε:  What does ogrinfo report on your shapefile? Can you send us the output?
Best regards,
Bart
> I have tried using TYPE POLYGON in this LAYER but mapserver keeps showing
> the error message:
>   msDrawShapes() General error message. Only polygon shapes can be drawn
> using a POLYGON layer definition.
>   I am using mapserver version 4.8.4 from the precompiled pack that is
> distributed from maptools.org. I can use TYPE LINE for the LAYER
> without getting any error but that doesn't result to the map I want to
> show.Any ideas?
>   Thank you for the response!
> "Bart van den Eijnden (OSGIS)"  έγραψε:  You should
> just use TYPE POLYGON. Note I think you need Mapserver 4.6 or
> greater, best to try with the latest release (4.8.X).
> Btw, Mapserver has a compile option determining whether or not it will
> pick up Z and M values.
> # If you want to use shape Z and M parameter this option must be set.
> # It's OFF by default.
> #USE_POINT_Z_M=-DUSE_POINT_Z_M
> USE_POINT_Z_M=
> Best regards,
> Bart
> K S wrote:
>> Hello everybody,
>>     I have a shapefile which is GEOMETRY:  3D POLYGON. How can i draw
>> the layer for this shapefile. To be more specific what would be the
>> TYPE of such a layer
>> Thank you in advance
>> Χρησιμοποιείτε Yahoo!
>> Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την
>> καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
>> http://login.yahoo.com/config/mail?.intl=gr
> OSGIS, Open Source GIS
> http://www.osgis.nl
 Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060727/932c5176/attachment.html
