Map File Problem?
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Fri Jul 28 10:55:45 EDT 2006
I'm not sure about your random problem...but you might want to check the
errors section of the mapserver documentation page, and battle those
errors one by one: http://mapserver.gis.umn.edu/docs/error
jeff
M.L. Jackson wrote:
> Hi. I am running mapserver 4.6.0-beta1 with Java Mapscript on Tomcat.
> While working on my project, I have encountered a weird series of
> errors. Everytime I restart the server and try to run my application, I
> get an error indicating what appears to be any random line in the map
> file. Most of the time the errors generated make absolutely no sense.
> Among the errors generated are "projection not named" and "major axis
> or radius = 0 or not given". The other errors are generally any line
> number with a piece of the map file indicated. Thanks for your replies.
> _________________________________________________________________
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
