SDE Compilation Help
Howard Butler
hobu at IASTATE.EDU
Fri Jun 2 12:03:07 EDT 2006
David,
MS4W already has SDE support included if you're using Windows. All
you need is the SDE C SDK installed and on your path. There are
instructions on what is necessary to swap in the distribution.
If on *nix, the Unix Compilation Howto has some information about SDE
<http://mapserver.gis.umn.edu/docs/howto/compiling_on_unix>.
Basically, all you need is the SDE C SDK installed somewhere for your
platform and you point configure at it.
Howard
At 10:19 AM 6/2/2006, Fawcett, David wrote:
>I want to compile in SDE support. =20
>Can anyone give me a list of the names of the SDE client libraries
>needed? =20
>Thanks,=20
>David.
