SDE Compilation Help
Fawcett, David David.Fawcett at STATE.MN.US
Fri Jun 2 12:21:49 EDT 2006
Thanks for the reply Howard.
I am trying to pull together the libraries for our server guy.  It is
for a Linux compile.
Can you just copy specific libraries to the server, or do you have to
run the install program and get the CAD client and documentation too?
David.
-----Original Message-----
Sent: Friday, June 02, 2006 11:03 AM
To: Fawcett, David; MAPSERVER-USERS at lists.umn.edu
Subject: Re: SDE Compilation Help
David,
MS4W already has SDE support included if you're using Windows.  All
you need is the SDE C SDK installed and on your path.  There are
instructions on what is necessary to swap in the distribution.
If on *nix, the Unix Compilation Howto has some information about SDE
<http://mapserver.gis.umn.edu/docs/howto/compiling_on_unix>.
Basically, all you need is the SDE C SDK installed somewhere for your
platform and you point configure at it.
Howard
At 10:19 AM 6/2/2006, Fawcett, David wrote:
>I want to compile in SDE support. =20
>Can anyone give me a list of the names of the SDE client libraries
>needed? =20
>Thanks,=20
>David.
