Template problems
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Fri Jun 2 20:47:18 EDT 2006
That would be:
myVariable0 = "[ROADS]";
Put that in the template and mapserver will set the value. If you want
an array, I think it is possible with something like the following
kwywords in the mapfile and place the follow code in each template:
HEADER   "/path/to/roads_header.html"
   <html>
   <head>
   <script ....>
       var ai = 0;
       var a = new Array();
TEMPLATE "/path/to/roads_query.html"
       s[ai] = "[ROADS]"; ai++;
FOOTER   "/path/to/roads_footer.html"
   </script>
   </head>
   <body>
-Steve W
Steve Lime wrote:
> Since templates are processed before the browser gets them then I don't see how this
> can possibly work. Why do you want to do that anyway?
> Steve
>>>> "Sievers, Jason" <jsievers at CO.LINN.OR.US> 6/1/2006 6:45:14 PM >>>
> Hello all.
> I have a MapServer HTML Template and am performing template substitutions.
> I would like reference values using JavaScript variables containing the
> template substitution.  For example, simply getting the MapServer version
> number is easy via "[ROADS]", where 'ROADS' is the name of a field in a
> dBase file.  But I want to get the value as a variable like
> myVariable0 = "ROADS";
> myVariable1 = '"[' + myVariable0 + ']"';
> Any thoughts are welcome.
> Thanks,
> Jason Sievers
