Apps timing out
Roland Martin
roland.w.martin at GMAIL.COM
Mon Jun 5 06:05:13 EDT 2006
I wonder if anyone's come across this before (I couldn't find anything
related to Mapserver & this error on the t'interweb)...
Since upgrading from MS4W 1.2.2 (Mapserver 4.6.1) to 1.5.1 (Mapserver 4.8.3)
a few weeks ago, I've been getting the following error on 2 of the apps:
(70007)The timeout specified has expired: ap_content_length_filter:
apr_bucket_read() failed
Which is logged in the error.log file on loading - it effectively means that
the page stays with the spinner for about 20 minutes before it loads.
I've gone through the code with a fine-tooth comb, and it now only seems to
be occurring in Internet Explorer - which leads me to suspect that either
(or both) the map file or the HTML may contain some unclosed tags or dodgy
code (although that's slightly surprising as they're all built from the same
template).
Anyone have any ideas? I'll send the related files if that sounds like the
most likely cause.
Ta,
Roland.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060605/95604a09/attachment.html
