[Fwd: Re: WFS gurus . . . .]
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Jun 5 10:49:23 EDT 2006
Good question.
What's your actual projection definition?
CubeWerx (http://www.cubewerx.com/) holds the 42xxx projection
definitions. We've worked with them to establish codes which are not
natively in EPSG. I've cc'd Craig here for info.
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Bob Basques
> Sent: Monday, June 05, 2006 10:38 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] [Fwd: Re: WFS gurus . . . .]
> Ok, we'll try that.
> Any rule-of-thumb for assigning an arbitrary code?
> bobb
> -------- Original Message --------
> Subject: Re: WFS gurus . . . .
> Date: Mon, 5 Jun 2006 10:32:23 -0400
> From: Kralidis,Tom [Burlington] <Tom.Kralidis at EC.GC.CA>
> Reply-To: Kralidis,Tom [Burlington] <Tom.Kralidis at EC.GC.CA>
> >=20
> > I'm trying to get a WFS output in a local coordinate system. =20
> >Everything=20 works just fine with a EPSG code, but our coordinate
> >system is not in=20 the list. Do we need to add it in in more than
> >one location? We're=20 using a few extensions that all
> seem to have
> >their own=20 version of a EPSG=20
> > code list, different formats and everything.
> What's your projection parameters? If it's indeed not an
> EPSG code, you'll need to add this to your proj install's
> epsg file, then cite that EPSG code in your WFS request. =20
> > All I need is to be able to get the WFS output with a same
> > coordinate=20 system BBOX. Can I get around the EPSG
> requirement with
> > some form of=20 fakery? Can the GML be output with a
> MODE=3D option
> > perhaps, in it's=20 native coordinate system?
